Calculating Magnetic Field of a Solenoid with Changing Amperage
The discussion focuses on calculating the magnetic field of a solenoid with a changing amperage, specifically with parameters of N/l = 100 turns/meter and dI/dt = 0.05 A/s. The magnetic field B is calculated using the formula B = μ*N/l*I, while the electromotive force (ε) is derived from the time derivative of magnetic flux (Φ). Participants emphasize the importance of correctly handling the derivative of the magnetic field concerning time to accurately compute the induced electromotive force.
  • Understanding of solenoid physics and magnetic fields
  • Familiarity with calculus, specifically differentiation
  • Knowledge of electromagnetism principles, including Faraday's Law
  • Experience with magnetic field equations, particularly B = μ*N/l*I
  • Study the application of Faraday's Law in dynamic systems
  • Learn about the relationship between current changes and magnetic fields in solenoids
  • Explore the concept of magnetic flux and its time derivatives
  • Investigate the effects of changing amperage on solenoid behavior
Students in physics or engineering, educators teaching electromagnetism, and anyone involved in electrical engineering applications related to solenoids and magnetic fields.
GermanMC
I've been given a solenoid and I have N/l = 100 turns/meter, dI/dt = 0.05A/s and a radius of 0.005m. I am only concerned with the dI/dt.
B = μ*N/l*I
\Phi = \int\int B\bulletn dl
\epsilon = d\Phi/dt
For B I get the field but how do I deal with my amperage in amps/s instead of just amps. Once I get that I'll take the derivative of the flux with respect to time and I'll be fine. Any clues will be much appreciated.
When you take d(phi)/dt of your 2nd expression, you can interchange the order of differentiation and integration because both are linear operations. d/dt comes inside and operates on B. You find dB/dt from your first expression, which looks wrong BTW. (Shouldn't I be in the denominator?)
