Does this series converge or diverge?
  • Thread starter Thread starter ghost34
    Series
The discussion revolves around determining the convergence or divergence of the series Ʃ (n+1)/((n^3)+3n^2+5)^1/2 from n=1 to infinity. Participants are exploring methods to analyze the series' behavior.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to use the comparison test and the ratio test but finds them inconclusive. Other participants suggest using the asymptotic comparison test and clarify its conditions. There is also a discussion about the powers of the numerator and denominator in the series.
Participants are actively engaging with different tests for convergence, with some providing suggestions for alternative approaches. There is no explicit consensus yet, but the conversation is focused on refining the methods being considered.
There is a mention of the original poster's uncertainty regarding the effectiveness of the comparison test and the ratio test, indicating potential gaps in understanding the application of these tests.
ghost34
does the following series converge or diverge? how does one determine whether it diverges or converges?
n=1, to infinity
I attempted to compare it with n/(n)^3/2, this series diverges and is greater than the original series, so the comparison test didn't work, at least in this case. the ratio test was inconclusive as well. any help would be appreciated, thanks
Try using the asymptotic comparison test. I'll write it down in case you don't know it.
If |a_{n}| ~ |b_{n}|
then
\sum |a_{n}| converges \Leftrightarrow \sum |b_{n}| converges
~ means "is asymptotic to".
a_{n} ~ b_{n} \Leftrightarrow limit {a_{n}}/{b_{n}}\rightarrow 1
It's a very very useful test.
Dansuer's suggestion is good, but you probably know it as the limit comparison test. The limit has to be non-zero and finite, not necessarily equal to 1.
The crucial point is that the denominator has "leading power" 3/2 while the numerator has power 1. The entire fraction has "power" -1/2. You should be able to compare it with 1/n^{1/2}.
