A problem in Griffith's textbook of electrodynamics, P189.
The discussion revolves around problems from Griffith's textbook on electrodynamics, specifically concerning the electric field in the presence of a linear dielectric material and bound charges. Participants are examining the implications of Gauss's law in this context and the resulting electric fields in two regions divided by a plane.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of Gauss's law to derive equations for the electric field in the dielectric and the role of bound charges. Questions arise regarding the interpretation of these equations and their alignment with Griffith's stated results.
There is an ongoing exploration of the equations proposed by the original poster, with some participants questioning their validity and the assumptions made. Guidance is offered regarding the interpretation of the electric field contributions from bound charges, but no consensus has been reached on the correct approach or final answer.
Participants note the importance of boundary conditions and the distinction between total electric fields and contributions from specific charge distributions. There is also mention of the need to consider the superposition principle in the context of the electric fields involved.
karlzr
Exercise 1:
Suppose a infinite plane z=0 divides the 3-dimensional space into two parts. The region below z=0 is filled with linear dielectric material of susceptibility \chi. The bound charge density at z=0 is \sigma. Find the electric field of the two regions.
Exercise 2:
The original problem in Griffith's book is to calculate the force on a point charge q situated a distance d above the the origion (x=0,y=0,z=d). The first step is to find the electric field E_z just inside the dielectric at z=0, which is due in part to q and in part to the bound charge itself. And he states that the latter contribution is
-\sigma/2\epsilon_0.
In my opinion, we should write two equations(from Gauss's law in terms of E and D respectively):
\epsilon_0 E_1+\epsilon_0(1+\chi)E_2=0
\epsilon_0(E_1+E_2)=\sigma
Then E_2 is my answer, which is quite different from the expression in Griffith's book -\sigma/2\epsilon_0.
I need a detailed solution to the electric field of this configuration.
What's the meaning of those two equations you write?
karlzr said:
In my opinion, we should write two equations:
Why, in your opinion, should we write these two equations?
Keep in mind that the boundary condition Eq 4.40 applies to the normal component of the total electric field when crossing a surface from one linear dielectric to another, not just the part of the (normal component) field due only to the surface charge there (which is what Griffiths' claims is \frac{\sigma}{2\epsilon_0}).
These two equations are two expressions of Gauss's law in terms of E and D respectively.
I modified my question as you can see. Now as to Exercise 1, do these two equtions hold?
Then the total electric field E_z should be the summation of the two parts.
You're right! However, The "E2" you write is not the contribution of the induced charge. The eletric field contribution of the induced charge is - sigma/(2*epsilon)
The E2 which you write is the "total" electric field just below the plate due to charge q and those induced charge.
I changed the way I put my question. What I don't understand is why the contribution from the bound charge is -\sigma/(2\epsilon_0). That is why I put forward Exercise 1, to consider the part of electric field from the bound charge. In this case, I think the equations are OK. Then E_2 is the result we are looking for, which can be added directly to the total electric field because of superposition principle.
