Best way to learn - use the solution manual often or not?
  • Thread starter Thread starter Nikitin
    Manual
The discussion revolves around the best strategies for learning physics and mathematics, specifically whether to frequently use solution manuals when encountering difficulties or to attempt problems independently for longer periods. Participants explore the implications of each approach on understanding and retention of material.
  • Some participants suggest that using a solutions manual can provide instant feedback and help confirm understanding after attempting a problem.
  • Others argue that relying too heavily on solution manuals may hinder the development of problem-solving skills and the ability to think critically through challenges.
  • A few participants express that there is value in struggling with problems, as it can lead to deeper understanding, although the definition of "struggling" varies among individuals.
  • Some contributors mention the importance of using solution manuals sparingly, primarily as a tool for checking work rather than as a primary resource for solving problems.
  • Concerns are raised about the potential for developing bad habits if students do not receive timely feedback on their problem-solving techniques.
  • Several participants note that the context of the course and the difficulty level may influence the appropriateness of using solution manuals.
  • There is a suggestion that the educational environment and grading practices may affect how students approach problem-solving and the use of solution manuals.
Participants do not reach a consensus on the best approach to using solution manuals. There are multiple competing views regarding their utility and the balance between independent problem-solving and seeking help from solutions.
Some participants highlight limitations in their experiences, such as the lack of access to solution manuals or the varying difficulty of courses, which may affect their perspectives on the discussion.
Nikitin
So what is the best way to learn physics, math etc.:
Do loads of problems by using the solutions manual every time you get stuck?
or
Do few problems but use the solution rarely, rather getting unstuck by thinking hard?
Thoughts?
Get unstuck by using Homework and Coursework questions Forum...:biggrin:
How strong do you think you get by watching other people lift weights?
Can get pretty strong if you learn the proper form from said people.
Is it really unreasonable to have a low threshold to use the solutions manual?? Many of my fellow students use it/ask other people almost immediately if they are stuck. To me this seems attractive, as you can spend much less time on problems that way, especially with courses like Fluid Mechanics, where I have little intuition.
But I realize there is allot of value in trying stuff out and experimenting, so I am split.. I'm very tempted in just giving in and start using the solutions manual freely, but I would like to know tips from you guys 1st.
And never lift yourself?
Why would you spoil all the fun by looking at the solution? Why solve anything then? Just read the solutions manual for practice.
I definitely would strongly advise a solutions manual just as long as you know how to use it properly.
If you're stupid enough to just copy the answers from the manual, then you're going to fail either way and you might as well just drop the post-secondary education to save some debt.
The most important thing about the solutions manual is that it gives you instant feedback after you have failed to do the question.
While using the Homework and Coursework Questions Forum is probably better for your understanding, if your load is high (such as in engineering), you can't afford to spend that much time since it is much slower than a manual.
I've been told not to check solutions at the end of textbooks , and I agree with the advice I received.Maybe you think "Oh I'm fairly certain that I could solve it if I spent an hour on it so why bother?" , well sometimes this might be true , but sometimes maybe you are selling the problem short and you would struggle for days.
If you're really struggling to learn a technique, I think it's OK to rely on a solutions manual.
But what "really struggling" means will vary from person to person. Towards the end of my university days, it wasn't unusual to spend hours (and hours) trying to "get" something.
It's good to get used to struggling, IMO.
It would certain be a lot cheaper, if the OP's thesis were true, to purchase only the solution manual for a course text rather than a bloated, overpriced textbook. Obviously, test taking would be a breeze if you only had to study the answer key.
I think it's fine to use to check your work, once you feel you've done all you can. However, getting an answer from a solutions manual is never going to stick with you like it will when you get it yourself. That "eureka" moment is really important for truly understanding something.
So use the solutions manual if you want, but know you're handicapping yourself in the long run.
There is no solution manual for anything you will ever get paid well to do. Otherwise, the person that wrote the manual would be doing your job. It's best to get used to this fact early.
If you need to check the SM on a problem that you are very stuck on, it's not bad. But if you immediately go to the solutions manual every time you get stuck, you'll never learn the correct method for thinking the problems through. If the solutions manual helps you to build your understanding of the problem solving methods for that topic, then use it (SPARINGLY). It should be there only to check your final answers, or to discover intermediate steps which you may not have thought to use.
You're friends in school will be in trouble if they don't learn how to think through a tough problem. Tests don't have solutions manuals, and as ZombieFeynman said, there's no solutions manual for problems you'll encounter in industry. Learn to do the problems without the manual. Work through them completely, then check to see if you did it correctly.
Guys, keep in mind that I'm obviously not advocating writing straight from the manual. I'm asking whether it's smart to spend a long time on cracking a stuck problem, or just try for 10 minutes and give up and look at how it should be done.
Thanks for the advice though. It seems that the consensus here is to use the manual sparingly - as I feared and as I have been doing throughout my life. Oh well, thanks for the help. Nothing like a free lunch.
Students aren't even supposed to have the solution manuals... I never used one. But, I never had any really tough courses.
Then you probably never had to deal with systems of PDEs.
At some point everybody needs to get a problem explained, or use a solutions manual. At least if they study a scientific/engineering subject.
or
I would say neither. My opinion is that you should do loads of problems and get unstuck by thinking hard :-p
Solution manuals are great for letting you see if you did it wrong or right. Of course try to get an answer first... But if you never see the solution you have no idea if you are doing it correctly or not. You can't correct bad habits if you don't know you have them. This is what homework should be about, learning - not testing. I think it can be not only useless, but counterproductive to spend loads of time solving problems with no idea whether your answers or technique are correct.
When I was in school, you found out if you were doing it wrong when your homework was graded. :smile: Homework scores were part of your grade, using a solution manual to correct your homework before turning it in was called...CHEATING. Is this no longer the case?
That would be nice! Its usually a little too late by then though, that's weeks after the material was covered.
Have you ever taken an upper level STEM course? Generally, there is either some sort of "solution manual" available, or at least a recitation component of the course where the professor will essentially walk through any particularly difficult problems. Also, these courses don't generally count homework as a significant portion of the grade. It's usually necessary to complete the assigned problems as a sort of participation component but the majority of the grade usually comes from exams. Homework is where you LEARN the material by grinding through problems, obtaining help when necessary, not so much to be tested on the material.
I think this varies depending on the course. In my upper level STEM courses there were certainly no solutions manuals available, and while there were problem sessions to go over the especially difficult problems, these problems had to be turned in beforehand. These courses also put an increased emphasis on the homework. In fact, the homework problems were often the primary assessment tool, not the exams.
I'm just saying, someone that uses something like the teacher's solutions manual to correct their homework before turning it in is cheating if it's being graded. If it's something you've been told to use, or it's notes from class, no problem. AFTER your homework has been graded and you find out you were wrong, that is when you can look at finished solutions to get help in finding out where your mistake was and how to solve correctly.
Since when did people start thinking it's OK to look at solutions manuals? The solutions manual exists so that your professor (or TA) can grade your homeworks without wasting his time solving the problems, because he has better things to do.
You, on the other hand, do not have better things to do, because you are a student, and doing homework is your job. The purpose of doing the homework problems is for you to learn how to reason through them. If you give up and look at the answer key every time you get stuck, you will never succeed at research, nor at life really, because people will always have to be holding your hand and giving you direction.
You are supposed to get stuck. Especially on things like "systems of PDEs". That's the entire point. You are supposed to get stuck, think harder about the problem, and come to some kind of realization that gets you unstuck. You are supposed to get used to this process, and get better at it. You are especially supposed to learn not to get frustrated when you are stuck, because that inhibits your ability to get unstuck.
For my research, I solve systems of PDEs way harder than anything you're doing in class, and there ain't no answer key. I get stuck for weeks at a time. I try some things, I make a few wrong turns, and I eventually figure things out. (Or not. Some things just go on the back burner for a while, until I get some new insight).
If you get totally stuck on one problem, put it aside and do other problems. Sleep on it. A lot of times, a new realization will come to you when you stop thinking about it and relax (especially if you sleep overnight). If you're still totally stuck, go to your prof's office hours and ask. He can probably guide you through the thinking process in a way that doesn't subvert your ability to learn.
^ Is it not possible that a solutions manual can help you learn how to reason through problems? It seems like those getting outraged at users of solution manuals are discounting how the manual is being used. You can use it wisely or use it as a crutch. Your arguments are only valid for the latter category.
Also, how does one succeed at life?
Very, very rarely did a professor assign problems that were available in a solutions manual. Profs know what's in the manual, they aren't dummies.
I always tried to learn the material before attempting the homework problems (much faster in the long run!). Problems worked out in class help with that, as do examples in the book. If used wisely, a good manual can also help.
Then, once you know the material well, you can do the homework problems.
FYI to everyone, the OP seems to be suggesting that he is using the solutions manual (whether it's the back-of-the-book or a separate thing) as his study aid, not for strictly for homework (though, obviously probably for homework too).
How unethical it is depends, for me, on what the homework is being used for. If it is being used for a measure of the students' understanding of the material (and therefore a significant portion of the grade), then it is wrong to use a solutions manual. If it is being used, as many STEM classes use homework, as an aid to students for tests (the grades being used typically as a little boost to overall grade, since most students do well on all the HW assignments), then I see no issue with using the SM properly. If it's available and you can find it, and you use it to assist yourself in learning the material then that's way better, in my opinion, than not being able to figure something out, getting a bad grade, and then going to a seminar afterwards which explains it the way a solution manual would anyway.
If the homework is there to help studenrs learn, and you use the SM to help yourself learn, then who are you guys to say that's wrong?
Here in the Norwegian technical university you need to get a minimum of 80% of homework done for you to get permission to take the exam. None of the homework is graded though, just approved. 90-100% of the grade is based on final exam scores (sometimes lab reports count towards the final score).
I mean naturally solutions manuals would be unavailable if the homework was part of the grade.
Ben Niehoff: True enough, being stuck is part of the problem and I admit I won't be using the solutions manual very actively due to the negative response in this thread. However, your "spend days on a problem" approach is completely impractical. I don't know how they do it in the USA, but here we have to go through many dozens of pages of engineering curriculum per week.
What you do is up to you, but I will offer a piece of advice my undergraduate class was given in our first physics class. My professor mentioned solution manual's and told us:
"Solution manuals are great tools for one thing: checking your math; but they will never teach you how to approach or solve problems on your own. When it comes down to the test you will have no help, and if you rely on the solutions manual, you will fail. This applies to your career after you graduate as well, as there are no help books for research."
If that's true, the education system has degraded even more than I thought. Lower level STEM courses have texts with solutions for the even numbered problems. Upper level undergrad, not so much. Graduate level classes? There oftentimes is no text. You're learning from published papers. How is "learning" from the solution manual going to prepare you for the graduate class where homework problems start with "develop a problem of your own making ...", or for working outside of school where there is no solution manual?
  • · Replies 71 ·
