Questioning Recurrence Relation: 3n-1 - an-1
The discussion revolves around a recurrence relation involving the counting of invalid strings based on certain conditions. The subject area includes combinatorial reasoning and string theory, particularly focusing on sequences that avoid consecutive numbers.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants are questioning the reasoning behind the formula for counting invalid strings, specifically why it is expressed as 3n-1 - an-1 instead of 3(3n-1 - an-1). They explore cases where the first two numbers in a string must be the same to meet the requirement of having consecutive numbers.
The discussion is active, with participants providing different interpretations of the requirements for valid strings. Some have offered reasoning to clarify the conditions under which strings are considered invalid, while others seek further explanation of the logic presented.
There is an ongoing debate about the definitions and assumptions related to the structure of valid and invalid strings, particularly regarding the placement of consecutive numbers within the strings. Participants are encouraged to articulate their reasoning more clearly to facilitate understanding.
Miike012
I boxed the portion of the solution that I am questioning.
How come the number of invalid strings is only 3n-1 - an-1 and not
3(3n-1 - an-1) ?
As you can see there are three cases (Which are to the right of the black box)
In all the three cases, the portion boxed in red is a string of length n-1 and does not have any consecutive numbers
Case 1:
The first number is a 1, then the second number must also be a 1
so that the string has a pair of consecutive numbers
Case 2
The first number is a 2, then the second number must also be a 2
Case 3
The first number is a 0, then the second number must also be a 0
3(3n-1 - an-1) ?
Case 1:
Case 2
Case 3
This is not true. There is no requirement that the "pair of consecutive numbers" be the first two. For example, 100 is a valid string with n= 3.
The string of length n has the requirment that it must have a pair of consecutive numbers, so if the 2nd term through the nth term of the string don't have a pair of consecutive numbers then the first term and second term must be the same inorder to satisfy the requirement.
3(3n-1 - an-1) ?
I don't understand your logic. The reasoning in the attachment starts with an invalid string length n-1. By definition there are an-1 valid strings of that length, and obviously there are 3n-1 total strings of that length. Therefore there are (3n-1 - an-1) invalid strings length n-1. For each such invalid string, there is exactly one way of tacking on an nth (at the given end) to produce a valid string length n.
If that doesn't help, I'll need you to spell out your own reasoning more clearly.
  • · Replies 18 ·
