Is Space Within Atoms Also Stretched by the Big Bang?
The discussion centers around the implications of the Big Bang on the nature of space, particularly whether the space within atoms (the distance between the nucleus and electrons) is also affected by the expansion of the universe. Participants explore concepts related to the creation of space, metric expansion, and the behavior of atomic structures in the context of cosmological events.
  • Some participants agree that space itself was created at the Big Bang, but express confusion over what "stretched the universe" means.
  • There is a contention regarding the usefulness of the concept of space as a "fabric" that can be bent or stretched, with some arguing it is misleading and oversimplified.
  • One participant suggests that the expansion of the universe should be understood as metric expansion, which may not affect atomic distances.
  • Concerns are raised about deriving physics from popular science media, with emphasis on the distinction between the Big Bang singularity and the Big Bang theory.
  • Some participants question whether the spacing between the nucleus and electron was proportionally lower just after the Big Bang singularity, with responses indicating that atomic spacing is not affected by cosmic expansion.
  • Discussion includes the idea that in the early universe, high temperatures prevented stable atomic formation, and that as the universe expanded, temperatures and densities decreased, allowing for atomic stability.
  • There is mention of a "mysterious thing" that influences unbound objects, which some attribute to dark energy or the cosmological constant, noting its negligible effect on atomic scales.
  • One participant speculates that accelerated expansion could imply a slight increase in atomic size, but this remains a theoretical interpretation.
Participants express a mix of agreement and disagreement regarding the implications of the Big Bang on atomic structure. While some agree on the creation of space, there is no consensus on the effects of cosmic expansion on atomic distances, with multiple competing views presented.
Participants highlight limitations in understanding the early universe and the nature of space, noting that many concepts are dependent on definitions and interpretations that remain unresolved.
vijayst
I watched a BBC video - Wonders of the Universe where the scientist explains that the Big Bang stretched the universe and created space. Is it true?
If the above assumption is true, is the space within atom (distance between nucleus and electron) stretched as well?
Space news on Phys.org
I will agree that space itself was created at the Big Bang but I don't know what "stretched the universe" could mean!
The whole concept of space as a "fabric" that can be bent or stretched is often discussed on this forum. The consensus is that it is a totally useless concept with no real meaning. Google "metric expansion" and/or see the link in my signature.
I agree, it's a misleading oversimplification of what really occurs. But unfortunately, so is "metric expansion"! :wink:
What is misleading about metric expansion? I've always seen it mentioned on this forum as a solid explanation.
In this context stretching doesn't mean creation of space, but most probably the enormous expansion of the universe by a factor > 10^30 (depending on the model) during the period of inflation. As was said already expansion should be understood as metric expansion.
The BBC video was produced by Prof. Brian Cox. According to him, the space that we inhabit is the same space that existed at Big Bang.
You would really do better to get your physics from somewhere other than pop-sci TV programs. Sometimes they get things right but they NEVER get everything right.
The "big bang" really has two meanings. First the "big bang singularity" and second the "big bang theory". The "singularity" is just the name for WHATEVER it was that happened before the big bang theory takes over. We don't know what that was. The big bang theory is a pretty well understood description of what happened AFTER the singularity, starting at about one Plank time after it.
So saying that
is fine if you mean that it is the space that existed AFTER the singularity
Is my conclusion that spacing between nucleus and electron proportionally lower just after the Big Bang singularity?
No, spacing of objects below the level of galactic clusers (that is, galaxies, solar systems, atoms, etc) is not affected. I say AGAIN:
the big bang singularity is a point in which our knowledge of physics can no longer explain what is going on this is prior to 10-43 seconds. The Hot big bang model, doesn't predict how the universe started, it only explains that the universe started at a hot dense state of unknown size and origin.
Space in and of itself is only geometric volume, it has no physical properties or energy to be warped, twisted stretched, etc. the statements curves space etc is misleading in that regard as it implies space has some separate property.
The geometric volume of space is filled with the existing energy mass contents of the universe as expansion occurs. So nothing is created, as space expands only the volume has changed
How particles and forces influence each other have mathematical geometric relations of influence, as the particles etc being measured occupy the volume of space, GR will use the term space-time curvature. Which describes how gravity influences the matter residing in space. (not that space itself has a property)
Universe geometry is the same in that the shape of the universe is a mathematical descriptive of the energy-density relations of all contributors,(matter,dark energy,gravity, etc) will have positive or negative pressure relations with one another, if the total energy-density is the same as or close to the critical density then the universe is flat. This is essentially a pressure distribution relation.
see here for more detail on Universe geometry
http://cosmology101.wikidot.com/universe-geometry p
page 2
http://cosmology101.wikidot.com/geometry-flrw-metric/
As expansion occurs there is simply more volume, the rate of expansion depends on the energy density relations as per above, energy-density of a type (radiation, matter, dark energy etc) has a corresponding energy-density to pressure relations is determined by its equation of state.
http://en.wikipedia.org/wiki/Equation_of_state_(cosmology)
Thanks, makes sense. Some mysterious thing pulls all objects which are unbound by gravity or nuclear forces. So, does not apply to atoms.
as to this question, in the early universe the temperatures was too high for atoms to form with stability, any atoms that did form would quickly decouple. Essentially all particles are in a state of thermal equilibrium. As the volume of space increases, the temperature drops in accordance to the ideal gas laws. So does the overall density. (atoms could not form until after inflation)
PV=nRT.
http://en.wikipedia.org/wiki/Ideal_gas_law
when the temperature drops enough different particles will drop out of thermal equilibrium. stable reactions of those particle species will start to form. However they drop out at different temperatures depending on which particle species etc. more details can be found in these two articles
http://arxiv.org/pdf/hep-th/0503203.pdf "Particle Physics and Inflationary Cosmology" by Andrei Linde
http://www.wiese.itp.unibe.ch/lectures/universe.pdf :" Particle Physics of the Early universe" by Uwe-Jens Wiese Thermodynamics, Big bang Nucleosynthesis
when you study cosmology in detail, it doesn't take long to realize that many of the metrics involved include the perfect fluid aspects and relations of thermodynamics in their equations. The FLRW metric and Einstein field equations included.
by mysterious thing pulling on things you might be referring to the cosmological constant or dark energy. The energy-density of the cosmological constant is easily overpowered by the strong force and gravity. Its influence is only at extremely large scales, (such as the regions between galaxy clusters).
expansion only influences the regions of space not gravitationally bound or the strong force. Its energy density per volume is too small to overcome gravity or the strong force.
... You can generalized it that way. It just that the thing that drove the expansion of space is very diffuse in proportion to let say an atom. It doesn't have a continuous work against the other forces that affects or binds an atom but it can be interpreted this way. The accelerated expansion can have a very small constant, a negative force between electron and nucleus that makes an atom slightly bigger than an atom in a non-accelerating universe model. However, Dark energy is treated as constant vacuum energy and it would a appear that atom already as it is.
If gravity according to GR is the warping of space, and even the Earth can exhibit frame dragging, then why is it incorrect to talk about the fabric of space? It seems to violate common sense, but then so does QM. And metric expansion seems like a proxy phrase.
the warping of space in GR is often misunderstood, the term spacetime has special meaning in physics
"In physics, spacetime (also space–time, space time or space–time continuum) is any mathematical model that combines space and time into a single interwoven continuum".
In other words the warping is simply a mathematical descriptive used in GR to describe the geometric relations between gravity and matter.(including light paths,etc) Not space itself, GR does not state that space has a fabric or substance.
any form of physics deals with mathematical relations, even particle physics. Most of the equations used in particle physics are in actuality differential geometry equations.
Mordred is correct. GR is a theory of geometry. In GR space-time is not represented by a "fabric", but with a mathematical description known as a tensor that describes how the geometry of space-time will affect objects, and how objects will affect the geometry of space-time. In other words, it describes how objects interact with each other by changing the geometry of space-time.
Note that there is NO description of a fabric, sheet, or anything else analogous to a physical object. It's pure geometry.
I know the Einstein GR equation is a tensor equation, and what tensors are. But GR must describe something physical , not just abstract differential geometry. If it changes the interaction of objects by changing the geometry of spacetime, then spacetime is something physical whose geometry can be changed. Of course the equation(s) do not mention fabrics, rubber sheets, or warping. Its a bunch of equations, or if you like G=T. Those are how physicists, including some very first-rate ones, have tried to explain GR to the lay public.
If GR is a theory of geometry, it belongs to math, not physics. This is the first time I've heard it described as a theory of geometry.
That depends on what "physical" means in this context, but I don't want to get into an argument over the meaning of words.
When I say that GR is a theory of geometry, I mean that it uses geometry to describe real, observable phenomena. The theory makes predictions that can be tested, and these tests have been verified. The theory accurately describes gravity, no one can argue this. As such, it is not a theory of math, it is a physics.
Physical means "stuff", matter and energy.
Hey, no argument from me that it makes predictions that have been verified. Eddington measured bending of light by the sun in what, 1919 or so, the orbit of Mercury was explained, and so on. Where we differ is the interpretation of some words. If you went back in time to 1 year after the BB, there would be a much smaller universe, I don't know what α(t) would have been. It got bigger, but not as in an explosion getting bigger. So something expanded. What?
You can go to numerous web sites about the metric expansion. Some agree with you, some with me, and some with neither. This is a case of "is to; is not".
I'm contributing nothing to this discussion, and am learning nothing, so will withdraw.
Then no, spacetime is not something physical since it isn't matter or energy.
The universe wasn't smaller, it was more dense. That is, the distance between everything was much smaller than it is now. As the universe expanded the distance between objects increased. The reason the distance increased is explained in GR as being a result of geometry, not of something being stretched. The reason most places explain it as "space expanding" or "space stretching" is because it acts in a very similar manner as a surface being stretched out, with the increase in distance between two objects proportional to the distance between them. In other words, the further apart two objects are, the faster they recede from each other.
It's important to understand that just because expansion acts similar to a surface expanding or being stretched, does NOT mean that spacetime is literally expanding itself. It is simply a useful way to help visualize the expansion. A key difference between expanding space and an expanding surface is that the surface is embedded within the framework of spacetime, while expanding space is part of the framework.
I disagree. I think this is a case of most people being unable to understand differential geometry. There are a number of misconceptions about numerous scientific topics, including the expansion of space. Most of these misconceptions disappear when you look at the actual theories and the math behind them.
I agree with this fully, when you look at the mathematics behind any field of study, and I've studied a wide variety. (even though I seldom discuss many of them) they all boil down to mathematical relations of interactions of one form or another
...It's bit odd. Despite the math you can't take away the presence of form in any equation. Maybe it is something fundamental and no wonder anyone can easily get hooked to it.
BTW. The stretching/curving came from a mental picture of geometry in GR intepreted as lorentz transformed sheets of patched spacetime and the presence of stuff/energy curves that plane. It is not completely wrong to talk about fabric(frictionless) as a metaphor and a secondhand picture. Besides, It's the closest we have to a physical picture that explains a 'part' of the phenomenon.
I agree for the purpose of a visualization aid, its completely handy. It can be a downright pain to have to constantly explain that it is a mathematical visualization each and every time. However the visualizations are easily misinterpreted.
Yes, indeed. One of the best examples in my opinion is the photon on the event horizon, which moves with c locally, but doesn't escape. There are explanations in popular science books saying well, the infalling space crosses the event horizon with c, that's why the photon can't escape. Its a picture which supports the 'fabric space' idea in the sense of dynamic properties, but is physically meaningless.
  • · Replies 31 ·
  • · Replies 25 ·
  • · Replies 33 ·
  • · Replies 27 ·
