Restrictions on Alpha for Validity of Laplace Transform Solution
The discussion revolves around an integral equation involving the Laplace transform, specifically focusing on the expression ty(t) = ∫₀ᵗ τ^(α-1) y(t-τ) dτ, with the constraint that ∫₀^∞ y(t) dt = 1. Participants are exploring how to express the Laplace transform Y(p) of y(t) and the implications of the parameter α on the validity of the solution.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the use of the Laplace transform to solve the integral equation and question how to incorporate the constraint ∫₀^∞ y(t) dt = 1 into their evaluations. There are attempts to derive expressions for Y(p) and explore the implications of different values of α on the solution.
The discussion is active, with various participants offering insights and suggestions on how to approach the problem. Some have noted the importance of the integral constraint, while others are exploring the implications of the parameter α on the solution's validity. There is no explicit consensus, but several productive lines of reasoning are being explored.
Participants are considering restrictions on α, particularly that it should not be a negative integer due to the presence of the gamma function in the expressions derived. The discussion also touches on the necessity of using the initial condition Y(0) = 1 in their evaluations.
Hoplite
I have the problem,
[tex]ty(t)= \int_{0}^{t}\tau^{\alpha-1}y(t-\tau)d\tau[/tex]
subject to the constraint that [tex]\int_{0}^{\infty}y(t)dt=1[/tex].
In need to get the answer in the form of, Y(p)=something (where Y(p) is the Laplace transform of y(t)).
I can see that the right hand side is [tex]Y(p)\frac{\Gamma(\alpha)}{p^a}[/tex], but how could I evaluate the left hand side?
That wasn't very clear but I think you are saying you want to solve the integral equation for y(t) and you are attempting to do so using the Laplace transform?
For the left side you just need to note that [itex]t e^{-st} = - \frac {d}{ds}e^{-st}[/itex], reverse the order of differentiation and integration and arrive at the desired result.
I'm actually just looking at a past exam question. It only asks me to find Y(p). I don't need to invert it afterwards.
OK, so we use [tex]\int_{0}^{\infty}ty(t)e^{-pt}dt[/tex]
[tex]=-\int_{0}^{\infty}\frac{d}{dp}(e^{-pt}y(t))dt[/tex]
[tex]=-\frac{d}{dp}\int_{0}^{\infty}e^{-pt}y(t)dt[/tex]
[tex]=-\frac{d}{dp}Y(p)[/tex]
and so, [tex]Y(p)\frac{\Gamma(\alpha)}{p^a}+\frac{d}{dp}Y(p)=0[/tex]
It concerns me, though, that I haven't actually used [tex]\int_{0}^{\infty}y(t)dt=1[/tex] in answering the question.
You should have used that condition when you evaluated the transform of the right side of the original equation.
I just used the property that [tex]L[\int_{0}^{t}g(\tau)y(t-\tau)d\tau;t\rightarrow p]=G(p)Y(p)[/tex] to slove for the right hand side. I can't actually see how I'd use [tex]\int_{0}^{\infty}y(t)dt=1[/tex] to do that.
Good point - that's the convolution theorem. Offhand, then, I can't see where the integral constraint comes in.
I'm going to guess that you're suppose to take the Laplace transform of [tex]t y(t)[/tex] and get [tex]-dY/dt[/tex], and then solve the differential equation:
[tex]-dY/dp = Y(p)\frac{\Gamma(\alpha)}{p^a}[/tex]
The definite integral he gave you will be necessary to pick out the particular solution of the DE that you need. Isn't it something like [tex]Y(0)[/tex]?
Carl
If I may summarize to help me an others understand this:
Letting:
[tex]\mathcal{L}\left\{y(x)\right\}=\int_0^\infty e^{-pt}y(t)dt=Y(p)[/tex]
we take the Laplace Transform of both sides of the eqution:
[tex]\mathcal{L}\left\{ty(t)\right\}=\mathcal{L}\left\{ \int_{0}^{t}\tau^{\alpha-1}y(t-\tau)d\tau\right\}[/tex]
Noting that the expression in brackets on the RHS is the inverse transform for the product:
[tex]Y(p)H(p)[/tex]
where:
[tex]H(p)=\mathcal{L}\left\{t^{\alpha-1}\right\}[/tex]
we arrive at the IVP:
[tex]-Y^{'}(p)=Y(p)\frac{\Gamma(\alpha)}{p^\alpha};\quad Y(0)=\int_{0}^{\infty}e^{-0t}y(t)dt=1[/tex]
Hoplite, you can solve for Y(p) right? Anyway, I get a form of Y(p) in which I am unable to invert. Would like to know the answer though.
Edit: Alright, I can invert it if alpha is 1/2 (I ain't proud). So what's the range for alpha?
Alright, I have a question. Do I need to take this elsewhere? You guys mind?
So I solve that equation in Y(p) above and using the initial condition given, I get, well, what do you get Hoplite? Anyway, so I let alpha=1/2 and arrive at a solution:
[tex]y(t)=\frac{e^{-\pi/t}}{t^{3/2}}[/tex]
So I wish to back-substitute this solution into the integral equation:
[tex]\frac{e^{-\pi/t}}{\sqrt{t}}=\int_0^t \frac{e^{-\pi/(t-\tau)}}{(t-\tau)^{3/2}\sqrt{\tau}}d\tau[/tex]
So, how do I show that the integral is equal to the LHS?
The DE can be solved by bringing Y stuff to the LHS and p stuff to the RHS for an arbitrary value of alpha. Then [tex]\int Y'/Y dp = \ln(Y)+c[/tex] works on the LHS and the RHS looks like [tex]\int p^{-\alpha} dp = p^{1-\alpha}/(1-\alpha) + c[/tex].
Carl
I got question #2. I just have such high hopes for integral and integro-differential equations in artificial intelligence. You know those guys at Blue Column are to use . . . but I digress.
Anyway, looking at the integral expression (for alpha=1/2) when t=1:
[tex]\int_0^1 \frac{e^{-\pi/(1-\tau)}}{(1-\tau)^{3/2}\sqrt{\tau}}d\tau[/tex]
Note that this has a vertical asymptote at tau=0. How do I know that the integral converges?
Hoplite, where you at with this anyway? I'm expecting plots you know. :smile:
The factor of [tex]e^{-\pi/(1-\tau)}[/tex] should go to zero a lot faster than the denominator.
Carl
Carl
Hey Carl. That's right for the upper limit. That is:
[tex]\mathop\lim\limits_{x\to 1^-} \frac{e^{-\pi/(1-x)}}{(1-x)^{3/2}\sqrt{x}}=0[/tex]
However for the lower limit, the numerator just goes to [itex]e^{-\pi}[/itex] and we're left with an expression:
[tex]\frac{e^{-\pi}}{0}[/tex]
However, I believe I have it using the p-test and limit tests:
P-test:
[tex]\int_0^1 \frac{1}{x^p}dx[/tex]
is convergent iff p<1.
Limit test:
If:
[tex]\mathop\lim\limits_{t\to 0}\frac{f(x)}{g(x)}=1[/tex]
then:
[tex]\int_0^1 f(x)dx[/tex]
is convergent iff:
[tex]\int_0^1 g(x)dx[/tex]
is convergent.
So let:
[tex]f(x)=\frac{e^{-\pi/(1-x)}}{(1-x)^{3/2}\sqrt{x}}[/tex]
and:
[tex]g(x)=\frac{e^{-\pi}}{\sqrt{x}}[/tex]
then:
[tex]\mathop\lim\limits_{x\to 0}\frac{f(x)}{g(x)}=1[/tex]
and becaues of the p-test:
converges and therefore:
does so as well.
QED
What the question says about alpha is, "Indicate any restrictions on alpha that may be needed for your solution to be valid. You are not required to invert the transform." As far as I can see, he wants the answer, alpha is not a negative integer because the presence of of the gamma function.
But I've got it now. It was this advice from Saltydog that I needed: [tex]Y(0)=\int_{0}^{\infty}e^{-0t}y(t)dt[/tex]
So, using,
[tex]-\int\frac{dY(p)}{dp}=\Gamma(\alpha)\int p^{-\alpha}dp[/tex]
So, for alpha is not equal to 1: (How do you do the inequality sign in LaTex?)
[tex]Y(p)=k.exp(-\frac{\Gamma(\alpha)}{1-\alpha}p^{1-\alpha})[/tex]
But Y(0)=1 => k=1.
[tex]Y(p)=exp(-\frac{\Gamma(\alpha)}{1-\alpha}p^{1-\alpha})[/tex]
Or, if alpha=1:
[tex]Y(p)=\frac{k}{p}[/tex]
But this blows up at p=0, so alpha cannot equal one.
(I'd love to know how many students actually got this one right.)
You mean residue plots? Not going to happen, I think. :smile:
Not invert the transform? That's like giving you a bicycle but saying you can't make the wheels go round and round.
Thanks Hoplite. It was a very interesting problem for me.:smile:
