MHB Understanding Initial Value Problems: Solving for y in y' = y-5 with y(0) = y0
The discussion focuses on solving the initial value problem represented by the differential equation y' = y - 5 with the condition y(0) = y0. The solution process involves using an integrating factor, leading to the general solution y(t) = 5 + C e^t, where C is determined by the initial condition. By substituting y(0) = 5 + C into the equation, it is concluded that C = y0 - 5. The final solution is expressed as y(t) = 5 + (y0 - 5)e^t, confirming the relationship between the initial value and the solution. The discussion emphasizes the importance of correctly identifying the constant C in the context of initial value problems.
karush
MHB
$\begin{align*}\displaystyle
y'&=y-5\quad y(0)=y_0\tag{given}\\
y'-y&=-5\\
u(x)&=\exp\int-1\, dx = e^{-t}\\
(e^{-t}y)&=-5e^{-t}\\
e^{-t}y&=-5\int e^{-t} dt = -5e^{-t}+c\\
&y=-5\frac{e^{-t}}{e^{-t}}+\frac{c}{e^{-t}}\\
y&=\color{red}{5+(y_0-5)e^t}
\end{align*}$
this is similar to one I posted before but can't seem to get the book answer (red)
the $y_0$ is ?
y'-y&=-5\\
\end{align*}$
the $y_0$ is ?
Note that:
$$-5\int e^{-u}\,du=5e^{-u}+C$$
And so after integrating, you should have:
$$e^{-t}y=5e^{-t}+C$$
Hence:
$$y(t)=5+Ce^{t}$$
Now, we are given:
$$y(0)=5+C=y_0\implies C=y_0-5$$
And so:
$$y(t)=5+(y_0-5)e^{t}$$
Does that make sense?
Ok
I had the C thing not happeningI noticed we get a lot of views on these!
