- 23,198
- 7,679
Tedima, there is no end to an infinitely long number.
The number 0.999... REPRESENTS a value that is equal to the number 1.
The division of 1 by 3 results in the repeating decimal 0.3333..., which is mathematically equivalent to the fraction 1/3. This operation does not yield a final answer in a finite form, but rather represents an infinite series that converges to 1/3. The discussion clarifies that while the long division process can be infinite, the value itself is exact and defined. Additionally, the concept of division by zero is addressed, highlighting that it is fundamentally different and undefined in standard arithmetic.
PREREQUISITESMathematics students, educators, and anyone interested in understanding the nuances of division, number representation, and infinite series.
Drakkith said:Tedima, there is no end to an infinitely long number.
Mark44 said:Where exactly is the end of an infinite number of 0's?
tedima said:0.9999 is smaller than 1 if i put 99p into my bank account it wouldn't show as £1 on the machine
Char. Limit said:Why is it that every week or so we get someone who claims that 1 cannot be divided by 3?
1 can be divided by 3. The result is 1/3. It's not my fault that the decimal expansion for that is infinite repeating.
tedima said:There is no end, 1 can not actually be divided by 3 in theory. Infinity is not a number... but yet u divide 1 by 3 and you get an infinite amount of 3's.
tedima said:i said in theory ;p
Drakkith said:We arent talking about 0.9999. We are talking about 0.9999...
The 3 decimals means that it repeats. Forever. If you started writing out the number, you would NEVER get finished.
Drakkith said:Sure you can. You don't get infinity as your answer, you get 0.333... with the 3's repeating forever. It is merely a consequence of our number system that we get a value with an infinite number of digits. For example, if we didn't use decimals at all, but always used fractions, we get an easy 1/3.
tedima said:I know what your saying. For 0.9999... to become 1 its got to be rounded up to 1. 0.9999... is the closest you can get to 1 but it isn't 1.
Drakkith said:No, that is incorrect. 0.999... IS equal to 1. There is no rounding involved.
Because that's the way we defined the real number system, and the use of decimal numerals to represent real numbers.tedima said:why is it equal to 1?
Hurkyl said:0.9999 only has a 9 in 4 decimal places. 0.9999... has a 9 in every decimal place.
tedima said:put 0.9999... in ur bank account ull se 0.9999... on the machine
Hurkyl said:Because that's the way we defined the real number system, and the use of decimal numerals to represent real numbers.
If we defined things in a way that 0.999... and 1 denoted different numbers, the resulting number system wouldn't be very useful. You're free to try and study such number systems if you like -- but none of them will be the number system you learned about in school.
Char. Limit said:Good luck "putting in" a number with an infinite amount of decimals into a bank account, an entity that usually doesn't go beyond the second decimal place.
Fact of the matter is, your "bank account" analogy doesn't apply here.
Also, it's spelled "your".
tedima said:So it was chosen 0.999... was equal to 1.
Drakkith said:Irrelevant. Your example has nothing to do with what we are talking about.
Hurkyl said:Effectively yes.
FYI, historically, we used the real numbers long before we ever had the idea to represent them with decimals. I'm not sure what the original idea for decimals was, but I would imagine the value of a decimal was originally meant to be an infinite sum. And the corresponding infinite sum that computes the value of 0.999... is a geometric series whose sum is 1.
Drakkith said:When you divide 1 by 3, you get .33333... repeating forever of course. My question is whether this operation could ever be considered to end. It looks to me like it's an invalid problem since you could never get a final answer, but simply keeping adding threes to the end of it when you try to solve. Does this make any sense?
Drakkith said:It was not chosen that specifically 0.999... should equal 1. It is simply the way our number system is set up that makes it that way.
caramon said:1 = 0.999...
Proof:
x = 0.999...
10x = 9.999...
10x - x = 9.999... - 0.999...
9x = 9
x = 1
