12 year old seeking feedback on multi-element blade alloy
  • Thread starter Thread starter Chloren
Chloren
I'm 12 and i theorized on a new alloy and was wondering if it is actually practical, it would be mainly used for blades such as Japanese Katanas as it's first inspiration.
I originally got this alloy from me questioning if soda can lids were sharp. This alloy has a titanium core/base that i chose because it provides toughness and a lightweight structure, Nickel to add flexibility and a bit of Heat resistance, manganese for impact distribution, Cobalt for structural stability wear resistance and edge integrity.
That was the core now onto the actual Edge of the blade, it'd have a thin steel outer layer that'd form the edge and hold sharpness, Chromium for Hardness and corrosion resistance and to increase edge hardness and make the sharpness of the blade last longer, and vanadium for micro-structure and grain enhancement strengthening the edge at a microscopic level and to improve edge retention. This type of blade design is called a "composite/layered blade design" similar to traditional katana forging but modernized.
I decided to make this alloy out of these metals because i was aiming for an all rounder blade and to have an all rounder blade with the resistances this one has I'd have to sacrifice ease of production and to add the least amount of metals possible while making production of said alloy hard but not impossible, and to not lean into fantasy. I also knew not to have drastically different melting points and stayed within the range 1250-1650 degrees celsius, 1250 to 1350 degrees celsius while melting the metals and 1550 to 1650 degrees celsius while fully liquid.
Keep in mind that this was my first ever metallurgy experience after hearing about metallurgy and not looking up any "guides" or "tutorials" or "lessons" on metallurgy and decided to challenge myself to trying to theorize an al rounder alloy made for katana forging or just blade forging in general. I also created a lesser version of this in around 26 minutes but refined it after 2 hours of work but consciously realized that any more metals would make the manufacturing process a literal hellhole or impossible fantasy.
I am also unsure if any of this would work in real world practice and am just theorizing after discovery. My design philosophy during this wasn't "more metals=better" but was "add the most amount of metals that would benefit each other and make an all rounder blade without making production impossible fantasy". And the actual goal of this alloy is to balance toughness + sharpness + flexibility + durability and to resist heat, blunt force, and wear, in total i was aiming for a multi-element superalloy that could make a top tier all rounder katana if forged correctly.
If I were to rate the alloy from my perspective i'd go on the low end and say 6-8.5/10 because of the many trade offs and manufacturability limits. This was my first time diving into metallurgy for fun and was wondering if you could point out any mistakes and answer a few of the following questions if possible:
Does this realistically make sense from a scientific perspective? Would the structure of metals be possible in practice? Are there any major issues with this concept? And is my melting range realistically achievable. (this is all theorization and not yet invented in real life)
Side Note on alloy name: After the 2 hours i decided to name this alloy "Hakichi" Ha from Hagane meaning "steel" in Japanese because of the steel edge, Ki from Kin meaning "gold" in Japanese because of the blunt force resistance and the durability and Chi from Chitan meaning "titanium" in Japanese forming these Japanese words into one make "Hakichi". I chose to have the name of the alloy in Japanese because i decided that if this were a real alloy i'd want it to be used in the production of top tier Japanese Katanas.
Welcome to PF.
The elements you add to an alloy, do not work to average all their properties. It is specific combinations of elements that benefit the iron by reducing unwanted characteristics. Those elements form different types of crystal structure, that are both hard, and will hold together.
https://en.wikipedia.org/wiki/Steel#Properties
Heat treatment is critically important because it can rearrange the crystal structure which changes the bulk properties of the material.
https://en.wikipedia.org/wiki/Heat_treating
You need to study phase diagrams of different alloys and notice in particular the eutectic.
https://en.wikipedia.org/wiki/Eutectic_system
Baluncore said:
Welcome to PF.
Thanks for your help and I will take your advice into mind, i didn't know much about metallurgy. I didn't realize that heat treatment mattered or that crystal structure mattered as much as you're describing it, i thought that each metal had it's own property and we'd just combine it. I'm still brand new to metallurgy (discovered it around 2 or 3 days ago) so this was my first concept.
You learn quickly, which is good because you have a huge and fascinating subject out in front of you, and the Sun is about to rise.
Seriously, @Chloren , to be thinking about this stuff at age 12 is impressive and admirable. Stick with it, there's an enormous amount of fascinating science and history to learn on metallurgy.
One might want to obtain a textbook on Titanium and its alloys. Soda cans are typically aluminum. Ti is expensive compared to aluminum.
One has not specified the composition, or quantities of the alloying elements. One might also want to review existing Ti alloys, and particularly those containing some Ni. One can find a list of Ti alloys in international standards, e.g., ASTM B348, or equivalent national standards. Ni is used in few Ti alloys. Sn, Al and V are more commonly used with other minor alloying elements. Ti alloys containing Ni are Grades 12, 13, 14, 15, 25, 33 and 34. Corresponding UNS numbers are: R53400, R53413, R53414, R53415, R56403 (a modification of Grade 5 R56400), R53442 and R53445, respectively.
Ti is a 'reactive' metal, i.e., it reacts readily with oxygen and moisture (reduces water to H and O) and forms TiO2, which tends to form on grain boundaries. Hydrogen forms Ti hydrides, and both oxides and hydrides embrittle Ti alloys. Consequently, Ti alloys are processed under a vacuum. Ni also can increase hydrogen absorption in Mg, Ti, Zr and Hf (all are hcp metals).
The more elements in an alloy, the more complex the microstructure. Some elements are soluble (solid solubility, or substitutional up to some solubility limit) in the base or dominant matrix, while some elements for separate phases (e.g., intermetallic compounds) with different microstructure and different properties.
Ti alloys are very different from steels (and even steels come in different varieties based on C levels and compositions) and Ni-based alloys.
Alloy design is a challenging but fascinating subject.
Continue being curious.
Edit/update: The following site has an article on a Ti-alloy for knives, namely "The Working Titanium Alloy: Ti4Al4V or Ti6Al4V (Grade 5)"
https://www.knifeart.com/titanium1.html
From ASTM B348, one finds Grade 5—UNS R56400. Titanium alloy (6 % aluminum, 4 % vanadium). The 6% Al and 4% V are nominal values; there are ranges for Al (5.5-6.75%) and V(3.5-4.5%) by mass. In such ranges, one usually targets the mid-point, or perhaps upper or lower half of the range depending on the element. The idea of a range is to allow for some variation from a nominal value, which is often seen in alloy production.
Grade 5 also has 0.08% max C, 0.20% max O, 0.05% max N, 0.015% max H, 0.40% max Fe. with other elements restricted to 0.40% max total.
One can find articles on specific Ti alloys on various sites. One such article on Ti-8Mn (UNS R56080)
https://www.azom.com/article.aspx?ArticleID=9389
BTW, Co is sometimes a tramp impurity with Ni.
Hi Chloren!
Welcome to materials science, I hope you continue to enjoy the topic. In general, deformation mechanisms in metals are dictated by defects in the crystal structure called dislocations (see wikipedia). Having solutes like carbon or chromium may serve to hinder their motion thereby making the material harder! Further, as some people have mentioned above, if the grains are very small this makes it hard for dislocations to move as well further contributing to the hardness you desire on the edge of your blade. (this is called the Hall-Peach relation). However there must be a balance between these strengthening mechanisms as they generally leave your material more vulnerable to fracture. This is why as you stated you want a milder spine of the blade to balance sharpness with resilience.
Do look into crystal structure (all metals are crystals) and the various phases and phase diagrams of these materials. For example the phase diagram for steel is a jumping off point for all metallurgy. Take it slowly and ask the people around you for help understanding these are tough concepts. Unfortunatley most of your teachers will probably be of little help as these concepts are reserved for college courses in materials science and metallurgy.
Good luck!
11K
10K
