What is the value of f'(1) for the series 1983 BC 5 part C?
  • Thread starter Thread starter keithk
The value of f'(1) for the series defined by f(x) = ∑n=0anxn with a0 = 1 and an = (7/n)an-1 is determined to be 7e7. The differentiation process leads to the expression f'(1) = 7(1 + 7 + 72/2! + 73/3! + ...), which aligns with the power series expansion of e7. The final conclusion confirms that both series converge to the same value, establishing the correctness of the solution.
  • Understanding of power series and their convergence
  • Familiarity with differentiation of series
  • Knowledge of the exponential function and its series expansion
  • Basic combinatorial mathematics, specifically factorial notation
  • Study the properties of power series and their convergence criteria
  • Learn about the differentiation of infinite series and its applications
  • Explore the exponential function and its Taylor series expansion
  • Investigate combinatorial identities involving factorials and their significance in series
Students and educators in calculus, mathematicians interested in series convergence, and anyone studying the properties of exponential functions and their derivatives.
keithk
Sum of a Series - 1983 BC 5 part C
I don't have the actual problem (this is for a friend) but this is what I could gather from what she was saying.
If f(x) = \sum^{\infty}_{n=0}a_{n}x^n find the value of f'(1)
a_{0} = 1 and a_{n} = (7/n)a_{n-1}
None maybe?
Ok so after differentiating,
f(x) = \sum^{\infty}_{n=1}n a_{n}x^{n-1}
Writing out the terms and subbing 1 for x got me to,
f(x) = \sum^{\infty}_{n=1}7^n/(n-1)!
or
f(x) = \sum^{\infty}_{n=1}n 7^n/(n)!
This was as far as I was able to get. Mathematica tells me that the answer is 7e^7.
I know that \sum^{\infty}_{n=1}n/(n)! = e and that \sum^{\infty}_{n=0}7^n/(n)! = e^7 (which doesn't really help because we're
starting at 1). But with both parts in there I'm not sure what to do
Ok I think I got it.
f(x) = 1/0! + 7x/1! + 7^2x^2/2! + 7^3x^3/3!... \sum^{\infty}_{n=0}\frac{7^nx^n}{n!}
f'(x) = 0 + 7/0! + 7^2x/1! + 7^3x^2/2! ... \sum^{\infty}_{n=1}\frac{7^n x^{n-1}}{(n-1)!} = \sum^{\infty}_{n=1}\frac{n7^nx^{n-1}}{n!}
f'(1) = 7/0! + 7^2/1! + 7^3/2! ... \sum^{\infty}_{n=1}\frac{n7^n }{n!} = 7(1 + 7 + 7^2/2! + 7^3/3!...)
e^x = 1 + x + x^2/2! + x^3/3! +x^4/4!... \sum^{\infty}_{n=0}\frac{x^n }{n!}
e^7 = 1 + 7 + 7^2/2! + 7^3/3! + 7^4/4!... \sum^{\infty}_{n=0}\frac{7^n }{n!}
Recall that:
and compare to e^7:
Which gives:
7e^7
Sorry if that is a bit hard to follow.
Ohh I can't edit it anymore...I think it is correct but I wanted to change the forms of some stuff.
I like this better, for example:
f'(1) = 7/0! + 7^2/1! + 7^3/2! ... \sum^{\infty}_{n=1}\frac{7^n }{(n-1)!} = 7(1 + 7 + 7^2/2! + 7^3/3!...)
I got the same answer as you, 7e^7.
By the power series: e^7 = 1 + 7 + \frac{7^2}{2!} + \frac{7^3}{3!} + \frac{7^4}{4!} + \ ... \ \frac{7^n}{n!}.
This matches the expression for \frac{f'(1)}{7} = 1 + 7 + \ ... \ \frac{7^{n-1}}{(n-1)!}, except that it ends with n-1 rather n. However since both are infinite series, they are one and the same.
