19th century matches: Chlorates without electrolysis?
The discussion revolves around the historical methods of producing chlorates in the 19th century, particularly focusing on non-electrolysis methods. Participants explore the practicality and feasibility of various chemical reactions and processes that could have been employed during that time, given the limited electrical power availability.
  • Historical
  • One participant notes the practicality of electrolysis for chlorate production but questions the existence of non-electrolysis methods, suggesting a theoretical pathway involving hot metal hydroxides and chlorine gas.
  • Another participant mentions that calcium hypochlorite, used as a bleaching powder, would naturally lead to chlorate production due to the disproportionation of hypochlorite, implying that chlorate production was a byproduct of the bleaching process.
  • A later reply discusses the challenges of separating chlorides and chlorates, proposing a method involving potassium chloride and fractional crystallization as a historical solution to this issue.
  • One participant references a video by a chemist that demonstrates chlorate production from bleach, indicating that methods were known and available during the 19th century.
Participants express varying viewpoints on the methods of chlorate production, with some agreeing on the role of calcium hypochlorite while others explore alternative theoretical methods. The discussion does not reach a consensus on a definitive historical method.
The discussion highlights the complexities of chemical reactions involved in chlorate production and the limitations of historical records regarding practical methods. Assumptions about the feasibility of certain reactions remain unverified.
JeffEvarts
First, I completely understand that electrolysis to produce chlorates is simple, practical, and inexpensive. I understand that electrolysis to produce chlorates was being used in the late 19th century. I'm wondering, given the (somewhat) limited distribution of electrical power at the time and the ubiquity of chlorates for the production of friction matches, if there was a practical non-electrolysis method of producing chlorates.
Wikipedia talks about combining "hot metal hydroxides" (presumably molten) with chlorine gas producing the chlorate. A balanced equation can be written:
6 KOH + 3 Cl2 = 3 H2O + 5 KCl + KClO3
But that doesn't mean it reacts that way. Indeed, the melting point of KOH is above the dissociation point of KClO3. :)
It appears that you could, theoretically, work your way up from hypochlorite, starting with chlorine gas dissolved in water, with lots of hydrogen chloride produced and discarded:
Cl2 + H2O
HClO + HCl
3HClO + heat → HClO3 + 2 HCl
KOH + HClO3 → KClO3 + H2O
But again, just because you can write the equations doesn't mean the reaction will happen or that it's practical.
Anyway, I'm curious about how "all that perchlorate" was made back-in-the-day. If anyone has a pointer to a practical historical method, I'm all ears. My Google searches all seem to turn up the electrolysis route, to the exclusion of everything else.
Chemistry news on Phys.org
Calcium hypochlorite was manufactured commercially as a bleaching powder for most of the 19th century, and it's almost impossible to prevent disproportionation of hypochlorite to chlorate and chlorine; so if you're in the bleach business in those days, you're almost stuck with production of chlorate whether you want to be in the business or not. The chlorine can be run back through the lime vats to produce more hypochlorite, so it's not a loss, and there is/was a market for the chlorate.
Thank you, bystander!
Reading up on bleaching powder, I see that excess chlorine beyond that required to neutralize the calcium hydroxide pushes things to a chloride/chlorate mixture, and that the two are difficult to separate. This process description addresses the problem of separating the chloride and the chlorate by the addition of potassium chloride, producing calcium chloride and potassium chlorate, which are then separated by fractional crystallization. This would certainly have been manageable and scalable historically.
Thanks again,
-Jeff
Nurdrage, my favorite internet chemist, has this video on how to produce chlorate from bleach:
Eau de Javelle was produced since 1792 in Javel, now part of Paris, so it was available during the entire 19th century.
