Homework Helper
- Messages
- 516
- Reaction score
- 11
Great! If you comment out everything dealing with neighbors in the localEnergy() function (the loop), and multiply the variable ener by .5f, you should get a curve that goes on top of the green one.
Finally, there are a couple of issues in the code you should be aware of. Most critically the way the random generator is instantiated: Each time a particle is created, it constructs a new (Mersenne-twister) random generator, std::mt19937, with default arguments. This means that the seed is always the same, which is a bad thing (each temperature is going to get exactly the same random numbers). To avoid this, one could make the variable static: "static std::mt19937 mGen;". This requires an instantiation, "std::mt19937 Particle::mGen = std::mt19937{};" somewhere in the code (usually in the .cpp file where you define the class, i.e. does not have to be inside a function). What static does is "share" the variable among all variables that are of type Particle (so mGen will be destructed only at program exit rather than when each Particle is destructed).
There might also be a correlation between the random number generator inside the particle and the random number generator that is used to sample the Monte Carlo energy condition. One might avoid this by seeding one of the generators from system time or something else (like a Singleton class for a global random generator etc).
These are issues you don't need to worry about for simple coursework, but if you start doing serious research and/or start noticing curious non-random patterns, these might turn out to be the culprits.
This might have been a bit difficult to follow especially if you're not very comfortable with C++.
