1D Quantum Well - Different width "naming" gives different result ?
2 replies · 1K views
Solmyros
TL;DR
Boundary conditions give different result depending on whether the quantum well is defined from 0 to L or from -L/2 to +L/2.
Greetings everyone,
Exactly as the title says. I am reaching to something strange and I do not know what I am missing. It must be something obvious...
case 1: -L/2 to L/2
After taking the Schrödinger equation and considering potential equal to zero inside we reach at this: $$Ψ=A×e^{ikz}+B×e^{- ikz}$$
Boundary conditions
Outside the well the potential is assumed infinite, so the wavefunction is equal to zero:
  • $$\Psi = 0, when \left|{z}\right|>\frac{L}{2}$$
  • $$Ψ(−\frac{L}{2})=0 \ (1)$$
  • $$Ψ(+\frac{L}{2})=0 \ (2)$$
From 1. we have : $$B=−A×e^{−ikL} \ (3)$$
Substituting (3) in 2. we get: $$k=\frac{n \times \pi}{L}, where \ n=0,1,2,... (4)$$
Therefore from (3) we get: $$B=−A \times e^{−inπ}$$
And finally, if $$n=2m, where \ m=0,1,2,...$$ we get from the original Schrödinger Equation: $$\Psi_{even}(z) = A \times ( e^{i k z} - e^{- i k z)} = 2 i A \sin{(kz)} \ (5)$$
case 2: 0 to L
After taking the Schrödinger equation and considering potential equal to zero inside we reach at this: $$Ψ=A'×e^{ikz}+B'×e^{- ikz}$$
Boundary conditions
  • $$\Psi = 0, \ when \ z \le 0 \ or \ z \ge L$$
  • $$Ψ(0)=0 \ (6)$$
  • $$Ψ(L)=0 \ (7)$$
From 1. we have : $$B'=−A'$$ (8)
So, we get from the original Schrödinger Equation: $$\Psi(z) = A' \times ( e^{i k z} - e^{- i k z)} = A' \sin{kz} \ (9)$$
and
$$Ψ(L)=0 = A' \sin{kL} \ which \ gives \ k=\frac{n \times \pi}{L} \ (10), where \ n=0,1,2,... (\ like \ before)$$
But, now if $$n=2m, where \ m=0,1,2,...$$ we get $$\Psi_{even}(z) = A' \sin({\frac {2m \pi }{L}z}) \ (11)$$
Normalization will eventually give the same amplitude, BUT, on the first case the wavefunction is imaginary. This added 'i' is what buffles me.
Thank you in advance for your help.
Wave functions with differing coefficients, real or complex of any magnitude, represent the same wave function. Normalization is required if observational probabilities are desired. Normalization makes them equal.
Reply
