1st derivative of a discrete function?
The discussion revolves around a problem involving the optimization of the volume of a rectangular box given the areas of two adjacent faces. The original poster expresses a desire to use derivatives in their approach but encounters challenges due to the discrete nature of the problem.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster attempts to express the problem as a function and considers using optimization techniques, while questioning how to handle the discrete nature of the dimensions. Some participants discuss the implications of treating the problem with continuous variables versus discrete mathematics.
Participants are exploring various interpretations of the problem, with some suggesting that the original poster's approach may be the most effective given the constraints. There is a recognition of the limitations of applying derivatives to discrete functions, and alternative strategies are being considered.
The problem is constrained by the requirement that all dimensions must be positive integers, which complicates the application of continuous optimization methods.
Bear_B
I have solved this problem but still have a question about it (problem and my solution posted below). What I wanted to do was express the problem as a function and use an optimization technique that would require taking the first derivative of the equation. The problem I ran into is: if using only positive integers, any function I could write out would have infinite discontinuities. Also, it does not seem like I could find the derivative of the function based on the definition of a derivative. Then I considered writing a discrete function, f(n). However, with the exception of series and sequences, I don't know how to deal with a discrete expression. I don't need a mathematical solution, but would just like to know the problem solving strategy that one would go through to optimize this problem similar to what I wanted to do.
Two adjacent faces of a rectangular box have areas 36 and 63. If all three dimensions are positive integers, find the ratio of the largest possible volume of the box to the smallest possible volume of the box.
V = l*w*h
Adjacent sides with areas 36 and 63 have a common side, which I will call h since that's how I drew it. Since all side lengths are integers, we need only consider the factors of 36 and 63.
Factors of 36 are: 18 * 2, 12 * 3, 9 * 4, and 6 * 6
Factors of 63 are: 21 * 3 and 9 * 7
The only two numbers common in both sets of factors are 3 and 9. Therefore, the largest volume box has h of either 3 or 9 and the smallest volume box has h of which ever (3 or 9) wasn't used for the largest volume box.
Using 3 for h: 3 * 12 * 21 = 756
Using 9 for h: 9 * 4 * 7 = 252
Ratio of the largest possible volume of the box to the smallest possible volume of the box:
756:252 -> 756/252 = 3/1
A simple geometric problem when approached like this, but I don't really like doing it this way because it seems boring.
[Edit: Spelling and format]
A discrete function does not have a derivative. You could try ignoring the "integer" condition and treat the lengths as continuous variables but that doesn't seem to give a satisfactory solution. It looks to me like your solution is the best.
Thanks. That's what I originally thought from my knowledge of what a derivative is, by definition. However, as previously stated, I have little to no experience formally working in discrete mathematics and was unsure of my comprehension of a derivative and if derivatives might apply to discrete mathematics as well.
I assert that many calculations boil down to:
  • Do interesting work to transform the problem into one that can be solved by "boring" rote methods.
  • Apply the "boring" method to finish the calculation
If I wanted to approach the problem with continuous methods, my first thought I would probably look at the (l,w) plane and find the point corresponding to the greatest volume. Then, I may be able to analyze the shape of the objective function to enumerate all integer (l,w) pairs in order of decreasing volume, and stop when I get to one for which h is also an integer.
Hurkyl, it just felt like the problem started "boring" and stayed "boring." Yeah, it ultimately seems to come down to a comparison of integer-value solutions for the box. Your way seems more "exciting" though.
