Solving a First Order ODE with y'(x)^2 = y^2 + xy and the Hint: u = y/x
  • Thread starter Thread starter Larrytsai
    Ode
The discussion focuses on solving the first-order ordinary differential equation (ODE) given by y'(x)^2 = y^2 + xy using the substitution u = y/x. Participants clarify the steps involved in transforming the equation and applying the substitution. The correct approach leads to the equation xu' = u^2 + u, which can be solved using separation of variables. The final solution involves recognizing that the variable u is related to y through the substitution y = ux.
  • Understanding of first-order ordinary differential equations (ODEs)
  • Familiarity with the method of substitution in differential equations
  • Knowledge of differentiation with respect to a variable
  • Ability to solve equations using separation of variables
  • Study the method of substitution for solving first-order ODEs
  • Learn about separation of variables in differential equations
  • Explore examples of first-order ODEs and their solutions
  • Investigate the implications of variable substitutions in differential equations
Students and educators in mathematics, particularly those focusing on differential equations, as well as anyone looking to enhance their problem-solving skills in calculus.
Larrytsai
y'(x)^2 = y^2 +xy
hint : let u = y/x
I divide x^2 on both sides and end up with...
y'= y^2/x^2 + y/x
then using the hint, i get
y' = u^2 + u
but i do not know how to solve the DE from here.
y'= y^2/x^2 + y/x
y' = u^2 + u
You should have
(1/x2)y'2 =u2+u
if u=y/x or y=ux, what is y' ?
whoops just gave the answer, don't want to destroy your thunder rock.
rock.freak667 said:
You should have
(1/x2)y'2 =u2+u
hmm how did u get y'/x^2?
EDIT:
Im a little confused, when taking the derivative of y= ux, am i differentiating w.r.t x?
EDIT:
yes, you differentiate with respect to x.
The left side was y'2, so dividing both sides by x2 means that the left side becomes y'2/x2
ohh sorry, only the x was squared for the left term not the y'
k so taking the derivative of y=ux, i have y' = xu' + u, and i just sub it into the equation, then i have xu' = u^2 + u which I can simply put it in the general first oder ODE form, and solve by separation
I have small query, is the term on the left yx2 OR (y')2 ?
Because y(x) is a function in x and y'(x) is its derivative, so y'(x)2 is the derivative squared, so which is it?
ohh yah, I meant y' * x^2
ah in that case, this post under this one is correct.
You will get xu' + u = u2+u, the 'u' will cancel and then you can solve by separation. then you need to remember that you will get 'u' and not 'y', but you know that y=ux.
great! thanks a lot for your help
