Simple Harmonic Motion - Potential and Kinetic Energy?
The discussion focuses on solving a problem related to simple harmonic motion involving potential and kinetic energy of a mass-spring system. The key points include the correct identification of variables, where "x" represents displacement from equilibrium, not amplitude, which is given as 0.47 m. Participants clarify that total energy can be calculated using the equation KE + PE = total energy, and that the spring constant "k" should be derived from the angular frequency and mass rather than directly from displacement. Miscalculations were addressed, particularly regarding the use of the wrong values for "k" and "x." Ultimately, the participant successfully resolved their issues with the help of others in the forum.
meganw
A 2.00 kg mass vibrates according to the equation x = 0.470 cos 8.36t, where x is in meters, and t is in seconds. Assume that x = 0.29 m.
(a) Determine the amplitude.
.470
(b) Determine the frequency.
1.331
(c) Determine the total energy.
(d) Determine the kinetic energy.
e) Determine the potential energy.
I did the first two parts (a-b), but I'm stuck on c,d & e, the questions about the Energy of the spring.
PE = .5kx^2
and
KE = .5KA^2
F/x=k
I've tried these 3 multiple times and I keep getting them wrong. One thing I'm not sure of, is is "x" the amplitude? I have been plugging in .29 for the "x" and .47 for the "A", but just curious if this is the reason I'm getting these wrong.
I would think, that according to these formulas, KE+PE=TOTAL ENERGY, and I thought I was doing them right. I'm at my wits end.
meganw said:
PE = .5kx^2
Good.
and
KE = .5KA^2
Not good. (This implies that the KE doesn't change!)
No. "x" is displacement from equilibrium.
These are correct.
Absolutely. What's the total energy?
Hint: Since total energy doesn't change, pick the easiest position to calculate PE + KE.
K.E + P.E = total energy
\frac{1}{2}mv^2+\frac{1}{2}kx^2=\frac{1}{2}kA^2
They usually give you that equation on formula sheets.
Does Ke=.5mv^2?
I don't know V, and I can't use w=v/r because I don't know R.
ALSO:
I tried to find Total Energy when PE is maxed out and v=0, but I got it wrong. I did
Total Energy=.5((9.8*2)/(.29))*(.29)^2
thats .5 * k * x^2
And Snazzy-I tried .5KA^2 as my total energy and got 2.986 and that's wrong...
The total energy is only given by \frac{1}{2}kx^2 only if x=A
You find A by looking at the equation of the motion because SHM follows the equation:
x(t)=Acos(\omega t+\phi)
Then you can find the potential energy at x=0.29m and then the kinetic energy at that point since you now have the total energy and the potential energy.
But I can't find KE because I don't know V and I can't find v using W because I don't have R...
I TRIED TO FIND PE AND GOT IT WRONG:
F=kx
x=.29
F=9.8*2
k=67.5862
SO
PE=.5(67.5862)(.29^2)
=2.842
Thank you so much for your help on this!
wrong
You don't need V or R or whatever to find the kinetic energy. You can use the fact that KE + PE = total energy
Well, x is not equal to A. So I guess I can't use the fact that .5kA^2 is total, and I keep getting PE wrong. :(
You get PE wrong because your value of k is wrong. F = kx at equilibrium, but x=0.29 is not the distance the spring has stretched at its equilibrium state. They usually give you the equation:
\omega =\sqrt{\frac{k}{m}}
And you CAN use the fact that \frac{1}{2}kA^2 is the total energy because A is GIVEN TO YOU IN THE EQUATION OF THE FUNCTION. The reason you got it wrong is because your value of k is wrong.
Okay, I tried it using x=.470 for my equation of the value of k, and I get k=41.7
but then I still get the wrong answer for PE...=1.753
I don't know why you're using the amplitude to find the value of k, use \omega and the mass to find the value of k as shown in the equation above. The spring does not stretch to its amplitude at equilibrium, nor does it stretch to the value of x the question gives you.
I GOT THEM RIGHT! =)
Thanks, you were SO helpful! I didn't realize that you can't always use the equation of F=-kx to find k!
I'm really thankful and grateful that you stayed online and helped me through each step. Thanks again, you're a really good person. =)
You can always use F=-k x at two conditions: that the F you use is the force exerted by the spring and that the x you use is the displacement of the mass from the equilibrium position. I am not sure why you concluded that you can't always use that equation but I wanted to point that out.
  • · Replies 51 ·
  • · Replies 21 ·
