2D distance theorem using gradient and speed-time product
  • Context: Undergrad
  • Thread starter Thread starter SpanishOmelette
    Theorem
2 replies · 1K views
SpanishOmelette
Hello fellow members of PF,
I believe I may have created a theorem for calculating the distance travlled on the 2-dimensional plane when gravity and other forces are ignored. Now, if this has been thought of before, that's not my fault. I have not studied this before.
The theorem is this... the distance traveled along the Y axis is equal to the gradient of travel divided by 90, then multiply the speed(m/s) by the time taken (s) (yes, this is d=vt), and then multiply both those terms together.
Then, to also find the distance traveled along the X axis, take v times t and then subtract from it the distance traveled along Y. Sounds fiddley in sentences. But I have enclosed a whiteboard sketch.
So, is this original? Does it work? Has it been thought of before?
Mahmoud.
g/90 x vt = distance moved in y, where g = gradient , angle.
motion along x = (vt) - (g/90 x vt)
jedishrfu said:
Your problem is that of projectile motion and you can determine if your nethod works by comparing it to how its done in introductory physics:
https://en.m.wikipedia.org/wiki/Projectile_motion
Does your solution when plotted on the xy plane produce a parabolic arc?
The OP is ignoring gravity.
No, it's wrong.
What you've done is to complicate simple trigonometry.
Given a right triangle that sits on the x-axis and the hypotenuse is the distance (d) and [itex]\theta[/itex] is the angle that you're traveling at (where [itex]\theta=0[/itex] is along the x-axis), then the distances x and y are
[tex]x=d\cos\theta[/tex]
[tex]y=d\sin\theta[/tex]
You can also replace d by vt if you wish, since d=vt. Also, [itex]\theta[/itex] is in radians. If you use degrees (g, to use your parameters) instead then you'll have to make the transformation
[tex]\cos\theta = \cos{\frac{\pi g}{180}}[/tex]
So finally you'll have
[tex]x=vt\cos{\frac{\pi g}{180}}[/tex]
[tex]y=vt\sin{\frac{\pi g}{180}}[/tex]
Now, g/90 may be incorrect, but it's not too bad of an approximation (for values between 0-90 degrees, but if you used more than that then it's way off), but a better approximation (which is just approximating sin(x) and cos(x) at [itex]x=\pi/4[/itex] radians, or 45 degrees) would be
[tex]\sin\frac{\pi g}{180}\approx \frac{1}{\sqrt{2}}\left(1+\pi\left(\frac{g-45}{180}\right)-\pi^2\left(\frac{g-45}{180}\right)^2\right)[/tex]
