How Does Force Angle Affect Book Acceleration with Friction?
The discussion centers on calculating the acceleration of a book with a mass of 0.55 kg subjected to a force of 4 N at a 15-degree angle on a table, considering static and kinetic friction coefficients of 0.45 and 0.23, respectively. The participants derived equations based on Newton's second law, ΣFx = ma and ΣFy = ma, and concluded that the acceleration in the x-direction is 5.2 m/s². The normal force was clarified as essential for maintaining the book's position on the table, with the final solution confirming that the vertical acceleration (ay) is zero.
  • Understanding of Newton's laws of motion
  • Familiarity with free body diagrams
  • Knowledge of static and kinetic friction coefficients
  • Ability to apply trigonometric functions in physics problems
  • Study the application of Newton's second law in two dimensions
  • Learn about the effects of friction on motion in physics
  • Explore the concept of normal force and its role in static equilibrium
  • Investigate the use of free body diagrams for complex systems
Students in physics courses, educators teaching mechanics, and anyone interested in understanding the dynamics of forces acting on objects in motion.
hri12
A book of mass M = .55 kg rests on a table where the coefficient of static friction us = .45. A force, F = 4 N acts on the book at an angle of 15 degrees above the surface of the table. What is the acceleration of the book if the coefficient of kinetic friction uk = .23?
ΣFx = ma
ΣFy = ma
Ff = Fn(uk)
I drew free body diagrams.
ΣFx = Fx - Ff
Fx - Ff = ma(x)
Fx - Fn(uk) = ma(x)
ΣFy = ma
Fn - Fy - mg = ma(y)
I'm not sure where to go from here. I know that I need to use Pythagoras theorem when I have the values of a(x) and a(y) but I don't know how to get that far.
Please help, I've been working on this for 2+ hours.
ΣFx = ma
ΣFy = ma
Ff = Fn(uk)
ΣFx = Fx - Ff
Fx - Ff = ma(x)
Fx - Fn(uk) = ma(x)
ΣFy = ma
What do you suppose the value of ay is ?
I know it's not zero because:
1. I already tried with zero and got the wrong answer.
2. It's being pulled diagonally upwards, so both a(x) and a(y) should have a nonzero value.
Edit: the answer should be 5.20 m/s^2
Never mind. Got it. Thanks everyone!
SOLUTION
ΣFx = Fx - Ff
Fx - Ff = ma(x)
Fx - Fn(uk) = ma(x)
ΣFy = ma
Fn + Fy - mg = ma(y)
a(y) = 0 (not sure why...)
Fn + Fy - mg = 0
Fn = mg - Fy
Fx - (mg - Fy)(uk) = ma(x)
a(x) = (Fx - (mg - Fy)(uk) )/m
a(x) = 5.2
((5.2)^2 + (0)^2)^(1/2) = 5.2
Excellent !
SOLUTION
ΣFx = Fx - Ff
Fx - Ff = ma(x)
Fx - Fn(uk) = ma(x)
ΣFy = ma
Then this is worth looking at further.
ay can possibly be positive, but it can't be negative. Right ?
If ay > 0, then the normal force will be zero. Right? Then Fy - mg = ay > 0 . Is Fy - mg > 0 ?
If that's not the case, then your solution with ay = 0 is correct.
Why will the normal force be zero? If anything the normal force will be Fn = ma(y) + mg -Fy...
I still don't understand.
I may not have stated that too clearly.
Why is there any normal force? It's there because the surface of the table keeps the book from accelerating downward through the surface. So the surface exerts whatever force is needed for this to be the case.
The normal force cannot be negative. If it were, it would be pulling down on the book.
If ay is positive, then the book is no longer on the surface of the table thus no normal force
So basically because the book isn't moving in the y direction? That makes sense.
Thank you so much btw for all of your help. :)
  • · Replies 22 ·
9K
13K
