2nd Level Vectors question. Tan ratios.
3 replies · 2K views
Darth Frodo
If I am only ginen the following how can I solve the whole Tan ratio part?
If vector U is 10 units
"Alpha Symbol" = Tan -1 (Tan inverse) 3/4 find U Vectors V = 13 units
"Beta" = Tan -1 (Tan inverse) 3/4 find V
I tried to multiply the 2 Tan ratios together but no luck.
I imagine you must work both V & U out individually.
I can add vectors and get their i & j components but this ratio has me stumped.
Thanks.
DF
Thanks.
DF
How are [itex]\alpha[/itex] and [itex]\beta[/itex] related to the vectors U and V? Are they the angles between the vectors and the positive x-axis?
First, thanks for the response.
"Alpha" is the angle between Vector U and the negative side of X axis
"Beta" is the angle between Vector V and the positive side of X axisNote: Both vectors stem from origin
V = <10cosβ, 10sinβ>
U can be written similarly, but you will need to find the angle that U makes with the positive x-axis.
Since β = tan-1(3/4), then tanβ = 3/4. Draw a right triangle whose legs are 3 and 4, and you should be able to find sinβ and cosβ.
You can do something similar to find the sine and cosine of the other angle (the angle that U makes with the pos. x-axis).
