2nd Order Differential Equation Problem
16 replies · 3K views
jonnejon
Let y be the solution of the initial value problem:
y'' + 2y' + 2y = 0 , y(0) = 0 , y'(0) = 5
The maximum value of y over 0 less than or equal to x less than infinity is ??.
r = -2 +/- i
I solved it:
y = c1 e^-2x cos(x) + c2 e^-2x sin(x)
y' = -2c1 e^-2x cos(x) - c1 e^-2x sin(x) - 2 c2 e^-2x sin(x) + c2 e^-2x cos(x)
y = c1 = 0
y' = -2c1 + c2 = 5 => c2 = 5
y = 5 e^-2t sin(x)
But I am terrible at trig. What is the maximum value of y? I got (x = -3pi/2 so therefore max y is 5 e^(6pi/2) but that is incorrect. I have one more attempt and don't want to lose out on this question.
Thanks.
Yeah, I missed that but doesn't change my answer much.
r = -1 +/- i
I solved it:
y = c1 e^-x cos(x) + c2 e^-x sin(x)
y' = -c1 e^-x cos(x) - c1 e^-x sin(x) -c2 e^-x sin(x) + c2 e^-x cos(x)
y = c1 = 0
y' = -c1 + c2 = 5 => c2 = 5
y = 5 e^-x sin(x)
But I still can't find the max value of y. Help please?
I think max of y is 5 e^(3pi/2) where x = -3pi/2. I don't want to exhaust my last attempt. Any confirmations?
I really don't know, my professor moves way to fast and doesn't give enough examples. I also completely forgot about that. If you show me how to do it instead of giving hints, I am sure I will learn it better that way. I would really appreciate that. Thanks.
And I'm sure that you will learn it better if you dig for it than if I just tell you. Crack your calculus book open and see if it has anything about finding the largest value of a function.
I am sorry, but I really don't know. I have been looking for awhile and I can't seem to find it. Did I do the differential equation correct though?
Yes, the solution of the initial value problem is y(x) = 5e-xsin(x).
Any maximum or minimum will come at an endpoint of the interval in question or at a point at which the derivative is zero. I truly hope that rings a bell with you.
Yeah, I found out that you set the derivative to zero but as I said before I am terrible at trigonmetry. So:
y'=5e^-x (cos(x)- sin(x))
0=5e^-x (cos(x)- sin(x))
5e^-x cos(x) = 5e^-x sin(x)
cos(x) = sin(x)
Whats next?
So, 0 = sin(x)/cos(x) = tan(x)? so tan (0)=0 so the max value of y is 0?
cos(x)/cos(x) does not equal 0...
what is 1/1, 5/5, pi/pi ?
Oh yeah, did the algebra wrong...
So, sinx/cosx = 1 = tanx
x=45?
so I should input the answer as:
y = 5 e^(-45) sin(45)?
x=45?
i think you need to put it in radians, but your method is correct
Yes!
I got it. Thanks Mark and Chewy. Yeah, I forgot to set my calculator back to radians, thanks for the help guys.
x=45?
There are an infinite number of solutions to the equation tan x = 1 on the interval [0, infinity). You have found only one of them. All you know is that dy/dx = 0 at x = pi/4. You don't know whether you have a maximum, minimum, or neither at this point.
Some thoughts on several of your comments...
You've mentioned a couple of times that you're terrible at trigonometry, you seem to have some trouble with algebra, and you didn't remember that the derivative of a function could be used to find the maximum and minimum values of that function. Now you are apparently in a class in differential equations, where knowledge of these areas is assumed. To be weak in all these areas is definitely not a recipe for success in differential equations.
I don't know what classes you are planning to take in the future, but you probably are going to have a much harder time of it until you can get up to speed in the areas where you are weak. I can't imagine that you are having an easy time of it in your present class.
