2nd Order Linear DE (homogeneous/wronskian/euler-cauchy)
  • Thread starter Thread starter anthony:)
    2nd order Linear
3 replies · 4K views
anthony:)
The equation [tex]t^2y'' + 4ty' -4y = 0[/tex]
has a solution of [tex]y(t) = t[/tex].
Find a second, linearly independent solution.
2. The attempt at a solution
Ok so I just applied the Cauchy Euler equation method to find a general solution of
[tex]y = c1*t^-4 + c2*t[/tex]
Where c1 and c2 are constants.
The problem stated that t was already a solution so I'm assuming that [tex]t^-4[/tex] is the other solution.
To determine whether they were linearly independent, I found the Wronkian which was
[tex]-5t^-4[/tex]
I know that two solutions of a DE are linearly independent if the wronkian is non-zero for all points where the solution space is defined, but in this case, the wronskian is only zero if t> 0 or t < 0. But it will be zero if t=0.
The problem does not include a range for t...
So basically, my question is : Could [tex]t^-4[/tex] be a second linearly independent solution of the DE?
Thank you.
welcome to pf!
hi anthony:)! welcome to pf! :smile:
(use {} round an exponent or subscript if it's more than one character :wink:)
[tex]-5t^{-4}[/tex]
I know that two solutions of a DE are linearly independent if the wronkian is non-zero for all points where the solution space is defined, but in this case, the wronskian is only zero if t> 0 or t < 0. But it will be zero if t=0. …
but y = t and y = t-4 are obviously independent!
i think you only need to look at the wronskian to check independence if you don't already know what the solutions are :wink:
[tex]-5t^-4[/tex]
You mean the Wronskian is non-zero if t > 0 or t < 0. And it is not zero when t = 0; it is undefined.
Also note that the leading coefficient of the DE is zero when t = 0. That gives a singular point at t = 0 which is why the domain for the solution doesn't include t = 0.
