2y'' + y' - y = x + 1; y(0) = 1, y'(0) = 0, y_p = ?
  • Thread starter Thread starter s3a
The forum discussion centers on solving the initial-value problem 2y'' + y' - y = x + 1 using the variation of parameters method. The user encountered issues with obtaining the correct particular solution, as verified by Wolfram Alpha. Key mistakes identified include the omission of the non-homogeneous term (x + 1) in the integrand during the integration process. The discussion emphasizes the importance of ensuring the coefficient of y'' is 1 for the technique to work effectively and suggests using LaTeX for clearer problem presentation.
  • Understanding of second-order differential equations
  • Familiarity with the variation of parameters method
  • Knowledge of complementary and particular solutions
  • Basic skills in LaTeX for mathematical typesetting
  • Study the method of undetermined coefficients for comparison with variation of parameters
  • Learn how to apply the variation of parameters method to different types of non-homogeneous equations
  • Practice converting differential equations to standard form with a leading coefficient of 1
  • Explore user-friendly LaTeX editors like LyX for efficient mathematical documentation
Students and educators in mathematics, particularly those studying differential equations, as well as anyone seeking to improve their mathematical typesetting skills for clearer communication of complex problems.
s3a
Solve the following initial-value problem, using variation of parameters.:
Variation of parameters: u_n' `=` W_n/W
I'm posting this thread, because I'm getting a wrong particular solution (according to Wolfram Alpha), and I can't find the mistake after reviewing my work numerous times. It doesn't matter which column, I put the fundamental set of solutions (from the complementary solution), right?
My (typed) work is attached as MyWork.pdf.
Any help in finding my mistake(s) would be greatly appreciated!
Why are you using variation of parameters? Once you have the complementary solution, it looks like an easy undertermined coefficients.
Anyway, when you do the integral, you also need to include (x+1) in the integrand. You've missed this out and just integrated Wi/W.
I'm using variation of parameters (instead of the method of undetermined coefficients, for example), because that's what the problem wants.
As for not including (x + 1) in each integrand, why must I do this? (I still can't see why it is not the case that I had to just integrate each W_n/W, alone.) Or, is it just a mistake in one of my two integrals?
You need to include (x+1) because that's part of the technique:
v_1 = \int \frac{g(x)W_1(x)}{W(x)}dx
But, with g(x) = x+1, you only have to look for Yp = Ax + B, and save yourself a lot of calculation.
Wait, now I'm really confused. My book only says v_n' `=` W_n/W, and I've done previous problems by only integrating W_n/W!
I'm attaching an example of a problem where I did just that (successfully)!
Is there something I'm missing? Did I somehow do what you're saying without realizing it, in that other problem (that I'm attaching with this post)?
Yes, I see you kept g(x) in W1/2. My mistake. I usually take it out and put (0, 1) in W1/2. To use this technique you need the coefficient of y'' to be 1. You've ended up with 2 x the correct solution.
But, the coefficients method is much easier.
@s3a: Since you are apparently typing your work anyway, why not just type it here? You would get more replies and it makes it easier for us to comment on various steps.
@LCKurtz:
Well, technically, I'm working on a desk where it's uncomfortable to handwrite my work, so I had them already typed up.
@PeroK, Which technique needs y'' to have a coefficient of 1? Mine? If so, could I just keep doing what I'm doing and divide my particular solution by the coefficient of the highest-order derivative of y, as a general procedure for all cases?
Well, the forum rules actually require that you type up the problem statement and work, not simply post images of them. I'll note that I ran across this and your other thread earlier, and I skipped over them because I didn't want to bother with opening another file just to look at your work. I know some of the other HHs do the same thing.
@Vela:
I remember reading that it's only bad if the image is not clear.
Having said that, I think I've found some extension to the software I use which allows me to type for myself just once, and copy over LaTex syntax into this forum, such that everybody wins.
I'll look into later for future postings.
@PeroK:
Thanks to you, I now get that all I have to do is exactly what I was doing except make sure that the coefficient of the highest-order derivative is 1, so thanks! :)
s3a said:
@LCKurtz:
You seem to by typing you work in WORD. For Math that is a painful waste of time. It would be better to use LaTeX, which you could then cut and paste into a Forum input panel.
Nowadays there are user-friendly versions available, such as LyX; see, eg., http://www.lyx.org/ . This is used much like WORD, with easy input, etc., but with math writing orders of magnitude easier than in WORD. It produces LaTeX-consistent output files. The best part: it is free.
  • · Replies 18 ·
