Unspecified gas, preasure known, looking for number density.
  • Thread starter Thread starter Buttons840
    Density Gas
The discussion focuses on calculating the number density and mean free path of air molecules in a vacuum chamber with a pressure of 7.00×10−11 mm of Hg at a temperature of 21.0°C. The pressure is converted to Pascals as 9.33 x 10−9 Pa. The relevant equations include the ideal gas law, pV = NkT, where p is pressure, V is volume, N is the number of molecules, k is the Boltzmann constant, and T is temperature. The participants confirm that assuming a volume of one cubic meter is appropriate for calculating number density.
  • Understanding of the ideal gas law (pV = NkT)
  • Knowledge of the Boltzmann constant
  • Ability to convert pressure units (mm of Hg to Pa)
  • Familiarity with concepts of number density and mean free path
  • Research the calculation of mean free path using the formula λ = kT / (√2 * π * d2 * P)
  • Learn about the properties of air and its molecular mass for accurate calculations
  • Explore the implications of low-pressure environments on gas behavior
  • Study the relationship between temperature and molecular velocity in gases
Students in physics or engineering fields, particularly those studying thermodynamics or fluid dynamics, as well as professionals working with vacuum systems and gas behavior analysis.
Buttons840
Integrated circuits are manufactured in vacuum chambers in which the air pressure is 7.00×10^(−11) mm of Hg. What are (a) the number density and (b) the mean free path of a molecule? Assume T = 21.0 C.
I've double checked, this is all the information available. Quoted verbatim.
101,300 Pa = 760 mm of HG. I was able to figure the pressure in Pa. Pa = 9.33 x 10^(-9).
I've seen various equations involving pressure and N (number density), but they all involve volume and other variables. p = (1/3)(N/V)(m)(v)^2 where v is the RMS velocity. I don't know the m value for "air", etc. I know N will be the number of molecules per cube meter.
I figured the pressure in Pa, but I don't know which formula to use when they all seem to have several unknowns. Am I missing something, or is the question not specific enough?
Thanks.
Ok. I see that pV = NkT. Where k is Boltzzmans (sp?) constant. T is temperature. Etc.
I suppose I just assume that V is a cubic meter, since the units of number density are molecules per cubic meter?
Yes, you are on the right track. k is the Boltzmann constant, and you need the number of molecules in one cubic meter.
ehild
  • · Replies 17 ·
