3rd order differential equation
The discussion centers on solving the third-order differential equation 5(d^3y/dt^3) + 3(d^2y/dt^2) + 7(dy/dt) + y = 4(d^2f/dt^2), where f(t) = cos(t) - 2sin(t). The user initially derived the second derivative of f(t) and attempted to solve the characteristic equation 5y^3 + 3y^2 + 7y + 1 = 0, resulting in complex roots. The solution approach suggested involves using the method of undetermined coefficients to find the steady-state output, which should be in the form of Acos(t) + Bsin(t) as t approaches infinity.
  • Understanding of third-order differential equations
  • Familiarity with the method of undetermined coefficients
  • Knowledge of characteristic equations and their roots
  • Basic concepts of steady-state analysis in circuit theory
  • Study the method of undetermined coefficients in detail
  • Learn how to analyze the steady-state response of linear systems
  • Explore the implications of complex roots in differential equations
  • Review circuit analysis techniques related to differential equations
Students and professionals in engineering, particularly those focusing on circuit analysis and differential equations, will benefit from this discussion. It is especially relevant for those seeking to understand the behavior of systems described by higher-order differential equations.
dominicfhk
I took differential eq-n class more than a year ago and I am having problem solving this problem.
5(d^3y/dt^3)+3(d^2y/dt^2)+7(dy/dt)+y = 4(d^2f/dt^2), where f(t)=cos(t)-2sin(t)
none
First thing I did was to take the second derivative of f(t) and multiply it by 4 for the right side of the equation, which turns out to be 4(-cos(t)+2sin(t))=-4cos(t)+8sin(t).
For the left hand side, I take its characteristic equation 5y^3+3y^2+7y+1=0 and tried to solve for the roots of the cubic equation, but turns out the roots are not whole & real numbers:
t1 = -0.15009708847612485
t2 = 0.22495145576193756+1.1321959748355932i
t3 = 0.22495145576193756-1.1321959748355932i
Then I am not sure how to proceed... or did I use a wrong approach? If not then how should I proceed the problem with what method? (undetermined coefficients?) Not sure if this helps, this differential equation describes a circuit with y(t) as the output and f(t) as the input. I was asked to find the steady-state output of the circuit. So I figure I should take the limit of the solution of the differential equation as t approach infinity.
Any help will be appreciated!
In the stationary state, the output will be of the same frequency as the input signal. The real part of all roots are negative, you made a mistake when copying them. The solutions of the homogeneous equation tend to zero with time. Assume the stationary solution in form of Acos(t)+Bsin(t) and solve for A, B.
ehild
