4Sine(4X) = -8Sin(2x) Double angle identity
  • Context: Undergrad
  • Thread starter Thread starter Tyrion101
    Angle Identity
11 replies · 4K views
Tyrion101
I kind of understand what to do with this when there are no numbers in front of the expressions, I also kind of understand that you can rewrite 4Sine(4x) as 4Sine(2x+2x) hat do I do with the 4 and 8? In an algebra problem you could divide the 4 into the -8, then simplify that expression, am I correct in assuming that taking just sin(2x+2x) can be written as: 2Sin(x)Cos(x) + 2Sin(x)Cos(x)? Or am I way off base in all of my assumptions? The explanation in my math book doesn't explain the whole problem.
Mathematics news on Phys.org
What do I do with the 2?
Expanding the (4x) this is the bit je ne comprends pas. (I don't understand)
I believe it is 2Sin(x)Cos(x) but you said that that was not how you did 4x, so now I'm thinking: Sin(2x)Cos(2x) Or it could be 2SinCos but that doesn't seem right. If the middle one is correct I think I may understand now.
No, and here's why. You cannot split up sin(2x + 2x) to sin(2x) + sin(2x) as if "sin" were multiplying (2x + 2x). You are confusing function notation with the distributive law, which says that a(b + c) = ab + ac.
sin(2x + 2x) is no more equal to sin(2x) + sin(2x) than is ##\sqrt{a + b}## the same as ##\sqrt{a} + \sqrt{b}##.
The gist of this problem, at least according to what you wrote in the thread title, is solve the equation 4sin(4x) = -8sin(2x).
Can you solve the equation 4sin(2y) = -8sin(y)?
Then I have absolutely no clue what is going on with that part of the problem, I know it relates somehow to the sum and difference identities, but the two with the x confuses me.
I think Mr @Mark44 is true.
Can you start solving this equation?
The only identity you need is
sin(2u)=2sin(u)cos(u)
What is the first step now?
The trigonometric identities for finding the sine and cosine of the sum of two angles are:
sin (α + β) = sin (α) * cos (β) + cos (α) * sin (β)
cos (α + β) = cos (α) * cos (β) - sin (α) * sin (β)
If you want to expand sin (2x) = sin (x + x), which implies that α = β = x, then
sin (2x) = sin (x) * cos (x) + cos (x) * sin (x)
sin (4x) = sin (2x + 2x), which implies α = β = 2x
I'll leave it to you to work out the rest of the expansion for sin (4x).
