4x4 Matrix Eigenvalues and Eigenvectors
5 replies · 3K views
jake96
I have 4 equations.
3x+6y-5z-t=-8
6x-2y+3z+2t=13
4x-3y-z-3t=-1
5x+6y-3z+4t=-6
I have already solved this matrix using gauss elimination and found that x=1, y=2, z=5, t=-2
Now the next part of the question asks to solve the matrix using eigenvalues and eigenvectors.
I have worked through to find the eigenvalues and received this equation
0=L^4 - 4(L^3) - 30(L^2) - 162L + 537, where L is lander
from this I found the Eigen values
2.2522
8.7456
-3.4989-3.8757i
-3.4989+3.8757i
Which I am fairly confident are correct.
However I am unsure about how to continue from here and how the corresponding eigenvectors will solve the matrix.
Thanks Very Much
Given that matrix A has eigenvalues [itex]\lambda_1[/itex], [itex]\lambda_2[/itex], [itex]\lambda_3[/itex], and [itex]\lambda_ 4[/itex], with corresponding eigenvectors [itex]v_1[/itex], [itex]v_2[/itex], [itex]v_3[/itex], and [itex]v_4[/itex], form the matrix P having those eigenvectors as columns and diagonal matrix D having the eigenvalues on its diagonal. Then [itex]A= PDP^{-1}[/itex]. The equation Ax= y is the same as [itex]PDP^{-1}x= y[/itex] and then [itex]DP^{-1}x= P^{1}y[/itex], [itex]P^{-1}x= D^{-1}P^{-1}y[/itex], and, finally, [itex]x= PD^{-1}P^{-1}y[/itex]. It is relatively easy to find [itex]P^{-1}[/itex] and [itex]D^{-1}[/itex] is just the diagonal matrix with the reciprocals of the diagonal elements of D on its diagonal.
Generally, the Greek letter lambda, λ, (not "lander") is used for the unknown eigenvalues, thus the characteristic equation is written:
λ4 - 4λ3 - 30λ2 - 162λ + 537 = 0
2.2522
8.7456
-3.4989-3.8757i
-3.4989+3.8757i
They are.
They are.
thanks, my bad. for some reason everyone I work with calls it lander instead of lambda
jake96 said:
I have 4 equations.
3x+6y-5z-t=-8
6x-2y+3z+2t=13
4x-3y-z-3t=-1
5x+6y-3z+4t=-6
2.2522
8.7456
-3.4989-3.8757i
-3.4989+3.8757i
Thanks Very Much
Does your question go on to explain what it means when it says "solve the matrix"? There are many things you can do with eigenvalues/eigenvectors; youcan use them to solve numerous, varied types of "problems", but I cannot figure out what problem the question is now asking you to solve.
