Solving 2nd-Order IVP as System of Equations
The discussion focuses on converting a second-order initial value problem (IVP) into a system of first-order equations. The original equation, $\dfrac{d^2x}{dt^2}+\dfrac{dx}{dt}'+4x=\sin t$ with initial conditions $x(0)=4$ and $x'(0)=-3$, is rewritten using the substitutions $x_1=u$ and $x_2=u'$. This leads to the system of equations $x_1'=x_2$ and $x_2'=-5x_2+\sin(t)$. The solution involves solving the associated homogeneous equation and finding a particular solution using the method of undetermined coefficients.
  • Understanding of second-order differential equations
  • Familiarity with initial value problems (IVPs)
  • Knowledge of systems of equations in differential calculus
  • Experience with methods of undetermined coefficients
  • Study the method of converting higher-order differential equations to systems of first-order equations
  • Learn about the method of undetermined coefficients for solving non-homogeneous differential equations
  • Explore the stability of solutions for linear differential systems
  • Investigate numerical methods for solving initial value problems
Mathematicians, engineering students, and anyone involved in solving differential equations, particularly those working with initial value problems and systems of equations.
karush
MHB
$\tiny{2.1.5.1.c}$ source
Change the second-order IVP into a system of equations
$\dfrac{d^2x}{dt^2}+\dfrac{dx}{dt}'+4x=\sin t \quad x(0)=4\quad x'(0)= -3$
ok I presume we can rewrite this as
$u''+u'+4u=\sin t$
Let $x_1=u$ and $x_2=u'$ then $x_1'=x_2$
substituting
$x_2'+x_2+4x=\sin t$
$\begin{array}{lllll}
&let &x_1=u &and &x_2=u'\\
&then &x_1'=x_2 &and &x_2'=u''
\end{array}$
so
$\begin{array}{llll}
x_1'=x_2\\
x_2'=-x_2-4x_1+\sin t
\end{array}$
so far
Since $x_2= x_1$ $x_2'= -5x_2+ sin(t)$. The associated homogeneous equation is $x_2'= \frac{dx}{dt}=-5x_2$ which we can write $\frac{dx_2}{x_2}= -5dt$. Integrating both sides, $ln(x_2)= -5t+ C$. Taking the exponential of both sides, $x_2= e^{-5t+ C}= e^Ce^{-5t}= C'e^{-5t}$.
Since the derivative of sin(x) is cos(x) and the derivative of cos(x) is -sin(x) we look for a solution to the entire equation of the form $x_2= A sin(x)+ B cos(x)$. Then $x_2'= A cos(x)- B sin(x)$ and the equation becomes
$A cos(x)- B sin(x)= -5(A sin(x)+ B cos(x))+ sin(x)$ so that $(A- B)cos(x)+ (5A- B)sin(x)= sin(x)$.
We must have A- B= 0 and 5A- B= 1.
mahalo that helped a lot...
  • · Replies 34 ·
