A basic ODE where Runge Kutta doesn't work?
  • Context: Graduate
  • Thread starter Thread starter h1a8
    Ode Runge kutta Work
6 replies · 5K views
h1a8
From a cubic function where y(0)=1, y(1)=0, and where there is a local max at y(5/13) I created a basic separable differential equation problem. I wanted to analyze how well different ordered Runge Kutta methods works in an interval [0,1]. Here it is:
dy/dt=-6(6/13)1/3(y-343/468)2/3 , y(0)=1
This ODE yields the cubic solution of
y=1/468(-12t+5)3+343/468
Now it is clear that y(1)=0
But using the several Runge Kutta programs with various computer software (mathematica, ti-nspire cas, mathstudio, etc.) yields a complex solutions for y(1). For example, using the classical RK4 with h=.1 yields
y(1)=0.718779+.005811i.
I don't see how the programs get a complex solution when all the functions have no even roots. Does anyone what is going on with these programs?
You have negative numbers in that root for y<343/468. All of the mentioned programs are won't to go to complex numbers ASAP. Those programs will take the principal root. For example, the principal root of (-1)2/3 is (-1+i√3)/2, not 1.
Yep.
Try dy/dt=-6 (6/13)1/3 ((y-343/468)(y-343/468))1/3 instead.
By multiplying (y-343/468) with itself first, you make sure that the argument to the power (1/3) is non-negative.
This way it will do what you intended.
I like Serena said:
Yep.
Thanks that works. I tried ((y-343/468)2)1/3 and that works too.
Didn't know the programs calculated the principle cube root of negatives by default even if they were complex.
Well, basically they don't have a choice.
What do you think (-1)^0.667 is?
Nice trick.
h1a8, this works because of the identity (ab)c=abc.
This identity is valid if a is positive and b and c are real. It is not valid in general. (The same goes with a lot of other exponentiation identities.)
