Finding the Identity and Inverse of the Operation *
  • Thread starter Thread starter roam
    Bit Thinking
The operation defined as a * b = ab + a + b has been analyzed for its identity and inverse properties. It was established that the identity element under this operation is 0, as a * 0 = a for all real numbers a. Additionally, every real number a has an inverse given by b = -a/(a+1), except for a = -1, where any b can serve as an identity. The discussion emphasized the importance of algebraic methods over trial and error for finding these properties. Overall, the operation exhibits a unique structure with specific identity and inverse characteristics.
roam
"Define a * b, for a,b \in R by a * b = ab+a+b. What we just have done is defined a new operation *, in terms of the well known ones multiplication and addition."
Is there a real number which is the identity under the operation * ?
Lets call this number e. A number for which a * e = e * a for all a \in R?
Furtheremore, does every a \in R have an inverse under this operation? ...if so, what could it be? :rolleyes:
Looks an awful lot like a homework problem to me!
To answer the first question, you are looking for a number e such that a*e= ae+ a+ e= a. That means ae+ e= 0 so ae= e for all a. There is no real number for which that is true so this operation has no identity.
(By the way "a*e= e*a" is true but does NOT define the identity. for example that is true for any member of a commutative group.)
To answewr the first question, you are looking for a number e such that a*e= ae+ a+ e= a. That means ae+ e= 0 so ae= e for all a. There is no real number for which that is true so this operation has no identity.
Err... Doesn't zero have this property?
Yep. a * 0 = a0 + a + 0 = a.
Oh, bother!
Okay, now that it has an identity, you need to find inverses for this operation. If b is a's inverse, then ab+ a+ b= 0. Solve for b.
I think so too. But if e is the identity, we should have a*e = ae+a+e=a and e*a=ea+e+a=a
=> e(a+1)=0 and e = 0 :wink: And yes 0 is the only solutions that works for every a \in R
In order to find the inverse we want for every a, a real number b for which a*b=ab+a+b=e=0
Then b(a+1)=0 => b= \frac{-a}{a+1} and we DO have an inverse under this operation for every real number except -1, by letting the inverse of a be the number \frac{-a}{a+1}.
:biggrin:
Take any invertible function f:R->R and you can define an operation a*b = f-1( f(a) f(b) ). The identity is f-1(1). The inverse of a is f-1(1/f(a)).
Yep, the answer is 0.
But just try different numbers to find an identity. Eventually you'll find it. Or you can do it algebraically:
a * b = ab + a + b = a (true for identity, since a * b = a)
ab + a + b = a
ab + b = 0;
(a+1)b = 0
For a = -1, any b is an identity. For a \neq -1, b = 0.
ab + a + b = a
ab + b = 0;
(a+1)b = 0
Just trying numbers is not a good method, especially when there are uncountably many to choose from. And b=0 works even when a=-1.
d_leet said:
Just trying numbers is not a good method, especially when there are uncountably many to choose from. And b=0 works even when a s1.
Yeah, solving it algebraically seems like a good approach.
I think the definable numbers would suffice, and they're countable. So it's not too hard after all. o:)
Note that since a and b are real numbers and multiplication and addition of real numbers are commutative, a*b = b*a for all real numbers a and b:
a*b = ab + a + b = ba + b + a = b*a, where in the centre we use the fact that ab = ba for real numbers and a + b = b + a for real numbers.
  • · Replies 24 ·
  • · Replies 18 ·
  • · Replies 26 ·
