A bit of confusion on a simple thermodynamics problem.
The discussion revolves around calculating the energy transferred in a house heated from 50°F to 70°F, focusing on two scenarios: an airtight house and one with air leakage. For the airtight scenario, the energy transferred is calculated as 3974 BTU using the equation Qin = mCv*(T2-T1). In the case of air leakage, the participants explore the complexities of mass loss and energy transfer, ultimately concluding that the energy transferred into the house remains effectively zero due to the escaping heated air. The ambiguity in the term "energy transferred in the house" is also highlighted, leading to different interpretations of the problem.
  • Understanding of thermodynamic principles, specifically the first law of thermodynamics.
  • Familiarity with the ideal gas law and its application in energy calculations.
  • Knowledge of specific heat capacities (Cv and Cp) and their significance in energy transfer.
  • Ability to manipulate equations involving mass, temperature, and energy in thermodynamic systems.
  • Study the application of the first law of thermodynamics in real-world heating scenarios.
  • Learn about the implications of air leakage on energy efficiency in buildings.
  • Explore the concept of energy transfer in dynamic systems, including partial differential equations.
  • Investigate the differences between energy content and energy transfer in thermodynamic systems.
Students and professionals in thermodynamics, HVAC engineers, and anyone involved in energy efficiency analysis in residential buildings will benefit from this discussion.
thepatient
A house with floor space of 2000 ft^2 and average height of 9 ft is heated from an average temperature of 50 degrees F to 70 degrees F. Determine the amount of energy transferred in the house assuming:
a) The house is air tight.
b) Some air escapes through the cracks as the heated air in the house expands at constant pressure.
Given values:
Floor space = 2000 ft^2
Height = 9 ft
Atmospheric pressure = 12.2 psia
Thermodynamic properties of air:
Gas constant R = 0.3704 psia ft^3/(lbm R)
Cv = .171 BTU/lbmR
Cp = 0.240 BTU/lbmR
PV = mRT
E in - Eout = change in energy of the system
Part a is relatively simple. Since we are treating the house as an airtight, constant volume, the equation for this would be:
Qin = mCv*(T2-T1)
where mass m = PV/RT = 1162.4 lbm, then
Ein = Qin, Eout = 0:
Qin - 0 = change of energy in the system
Qin = 1162*(.171)*(20) = 3974 BTU
Part B is where I'm a bit unsure of. I feel there is some missing information.
Since air leaks, we should have a loss of mass in the system, right? So we should have on the energy equation:
m1*qin - m2*qout = m3*cp*(T2-T1)
where q denotes heat per unit mass.
Which would mean energy is lost through mass transfer. Is this correct?
Using the ideal gas law, m1T1 = m3T3, so the mass remaining in the house after expansion would be:
m3 = 1118.6 lbm
Meaning m2 = 1162-1119 = 43 lbm.
So:
1162lbm*qin - (43lbm)*qout = (1118.6lbm)*(0.240 BTU/lbmR)*20R
1162qin - 43qout = 5369 BTU
But this leaves me with two unknowns and one equation. Should it be assumed that the amount of energy lost through the cracks is negligible?
For part B, the number of moles of gas remaining in the house will be a function of temperature: n(T).
The heat required to change the temperature from T to T+dT will be dQ = n(T)CpdT.
See if you can use the ideal gas law to find an expression for n(T). Then see if you can integrate the expression for dQ.
[EDIT: Sorry, I'm used to thinking in terms of moles, n, rather than mass, m. Please replace n(T) by m(T) above.]
Seems to me that in part b you need to consider it as a dynamic process and obtain a differential eqn. The air that leaks initially will be cooler (taking away less energy) than the air that leaks later.
Edit: beaten to the punch by TSny
I think involving the changes in mass, changes in temperature and changes in time in one equation will give me a partial differential equation.
I just found the solution by the author of my textbook and it looks like they neglected air loss. :\ They simply used:
Qin = m*cp*(T2-T1) = 1162*.240*20 = 5578 BTU
I don't like where they assume we will assume these things. Many problems in the textbook are like this.
Now that I see the solution I can see why we can neglect energy loss due to mass loss since, if we were to assume the exiting mass were at the same energy per unit mass as the energy that goes into the house (which would give an upper limit in error):
q per unit mass in house = 5578 BTU/(1162 lbm) = 4.8 BTU/lbm
energy leaving house = mlost * q per unit mass = 4.8 * 43 BTU = 206.41 BTU
so:
Error = 206.4/5578 = 3.7 percentBut these things aren't always clear unless you know the solution.
I strongly dislike looking at a solution manual. :( Thanks a ton for taking the time guys. :]
For air acting as an ideal gas, the energy content of the air in the room (a definite volume) is independent of the temperature when the pressure must remain fixed. If we subtract the volume of the escaped air we nullify the effect of the increased temperature. So the extra energy provided by the heater is carried away by the air that escapes through the cracks! So paradoxically the energy IN the room remains same! The amount of energy transferred IN the house is therefore zero.
Depends what you think "energy transferred in the house" means. It's a curious expression. To me, all the energy from the heater was transferred in the house, but some later escaped.
Oh I assumed "energy transferred in the house" to mean
(Energy content of air contained in house finally ) - (Energy content of air contained in house initially)
The problem statement expects us to assume that "energy transferred in the house" is same as the total energy transferred by the heater. With this understanding I agree with the solution given in OP's book. In this case the addition of the extra word "house" leads to ambiguity!
  • · Replies 20 ·
9K
9K
11K
