A block on an accelerating wedge
4 replies · 2K views · last reply
Leo Liu
This is a statement.
This is an equation.
Diagram of a block resting on a wedge inclined at angle theta, with gravity g pointing down and horizontal acceleration a applied to the wedge to the left, on a horizontal surface; beside it is the printed problem 3.8 Block and wedge.
For question b, the official solution sets up a non-inertial coordinate on the block and writes out the following two equations:
$$\begin{cases}
\begin{align*}
f\cos(\theta)+N\sin(\theta)-mg=0 \qquad \hat\jmath
N\cos(\theta)+f\sin(\theta)=ma \qquad\quad\;\;\, \hat\imath
\end{align*}
\end{cases}$$
Free-body diagram of a block on an inclined wedge accelerating to the right with acceleration a, showing friction f up the incline, normal force N perpendicular to the surface, weight mg downward, and angle theta.
The questions above are true because the horizontal acceleration of the block must be the same as the acceleration of the wedge to keep the former on the latter.
However, if I try to solve for the normal force using (2), I will obtain ##N=\frac{mg}{\mu \sin(\theta) + \cos(\theta)}## which shows that the magnitude of the normal force is independent to the acceleration.
This counterintuitive conclusion confuses me-- if you push it with a greater horizontal force, the block will be pinned harder to the ground because the block needs a stronger force to accelerate in lockstep with the wedge, and therefore creates a larger normal force. Could someone explain me why this is the case? Thanks in advance :).
When you solved for the normal force, you assumed that ##f = \mu N##. This is the value of ##f## when the acceleration has the specific value that puts the block on the verge of slipping. For general values of acceleration, you cannot assume ##f = \mu N##.
So can you please tell me what the friction force will be if the block is not on the verge of slipping?
##f## and ##N## will depend on the acceleration of the system. When the block is not slipping, then you can use your two equations to solve for ##f## and ##N## for a given acceleration.
Oh I think I get it-- in this case the value of the acceleration will be constant, which means that we still have two variables to solve. Thank you!
