A difficult integral, perhaps involving trig substitutions?
  • Thread starter Thread starter icosane
    Integral Trig
12 replies · 4K views · last reply
icosane
The integral of 1/(1+x^6) dx
This problem was given as a "challenge/bonus problem" on the first day of Calc 2, earlier today. Considering we were going over trig substitutions, I suppose there is probably some trig trick to it. Doing it by parts isn't helping... I just get a longer more messy expression to integrate. I also tried a u substitution. I set u = x^(3) to make the integral seem like I could pull out an arctan, But I keep ending up only making the situation worse.
I've typed in the expression into an online integral calculator so I know what the answer is, but I'm confused on how to go about tackling this problem. Any help would be greatly appreciated.
The denominator can be factored into (x2 + 1)(x4 - x2 + 1), and the quartic factor can be factored into (x2 - 1/2 - i/2*sqrt(3))(x2 - 1/2 + i/2*sqrt(3)). At that point you could break up the integral using the technique of partial fractions.
Thanks mark, can you give me the name of the technique used to factor out the quartic function, or give a little explanation yourself? I can see that it works but I'm curious as how one would go about splitting up a quartic function using imaginary numbers. I have yet to come across this technique in any of my classes. The answer I got for the integral is quite long so I'm not going to write it out but I used the integral calculator found at http://integrals.wolfram.com/index.jsp
Thanks again
All I used to factor the quartic was the quadratic formula, since this particular quartic was quadratic in form, with a 4th-degree term, a 2nd-degree term, and a constant term.
If you substitute u = x2, the quartic part becomes u2 - u + 1 = 0, and then use the quadratic formula to solve for u (= x2).
Okay, I sat down today and tried to solve the thing and still can't get it. When I do the partial fractions method I just end up with long ridiculous equations with imaginary numbers in them that don't cancel out. Am I supposed to split up each of the terms again? Or is there a whole different way to approach this problem? I was talking about it with someone who knows how to do it but won't tell me and he looked confused when I mentioned imaginary numbers.
Also just for reference the answer the online integral calculator gave was...
(sqrt(3)*log(x^2+sqrt(3)*x+1)-sqrt(3)*log(x^2-sqrt(3)*x+1)+2*atan(2*x+sqrt(3))+2*atan(2*x-sqrt(3))+4*atan(x))/12
Notice that [tex]x^6 + 1 = (x^2 +1)(x^4 - x^2 + 1)[/tex].
Since [tex]x^4 - x^2 + 1 = (x^2 + 1)^2 - 3x^2 = (x^2 + 1 - \sqrt(3)x) (x^2 + 1 + \sqrt(3)x)[/tex] **Note that the x is not under the sqrt sign**
And so [tex]x^6 + 1 = (x^2 +1)(x^2 + 1 - \sqrt(3)x) (x^2 + 1 + \sqrt(3)x)[/tex].
You can now use partial fractions.
[tex] x^4 - x^2 + 1 = (x^2 + 1)^2 - 3x^2 [/tex]
Thanks for the quick reply! I see that this works... is this a common algebraic maneuver for factoring quartic functions? I have never seen anything like this up to this point.
I encountered this question a couple months ago, and after a couple frustrating days I finally realized what the trick was.
It was the first time I've also seen something like it :)
You complete the square and obtain a difference of squares, so you can easily factor from there. If I spot a root immediately, then I use synthetic division; if not, then I use this method. But that's just me :)
:frown:
I keep coming back to this trying to solve it and just can't get it. Am I supposed to set up partial fractions over the these three terms,
because even if I did, I wouldn't know how to integrate A/(x^2+1+3^(1/2)*x)... but when I try to split that up using the quadratic formula I get another imaginary number. Am I just supposed to use partial fractions over those 3 terms and then just use integration by parts to solve for some constant over a quadratic?
When doing partial fractions with quadratics in the denominator, you must use Ax+B, Cx+D, and Ex+F, not A, B, and C. After you do partial fractions, you can algebraically manipulate each expression. For instance, let's say you have to integrate 2xdx/(x^2+sqrt(3)*x+1). You can rewrite this as the integral of (2x+sqrt(3)-sqrt(3))/(x^2+sqrt(3)*x+1). You can then split this up into two integrals; for the first one, you can use substitution, and for the second you will have to manipulate it again by completing the square in the denominator and then using a trig-sub (your answer will involve arctan).
It would be Ax + B and Cx + D and etc for the numerators, not just a single A B or C constant. If you end up with just a constant, like A/(x^2+1+3^(1/2)*x), then you could complete the square and integrate for an arctan solution.
