A few questions - I want to make sure I did it right
  • Thread starter Thread starter nyclio
The discussion revolves around a physics test involving momentum and energy conservation in a completely inelastic collision. The participant correctly calculated the linear momentum and kinetic energy before the impact but miscalculated the momentum and kinetic energy of the combined masses after the collision. The correct final velocity after the collision is 0.4 m/s, leading to a momentum of 0.6 kg*m/s and a kinetic energy of 0.899 J. The participant also sought clarification on the amplitude and period of the harmonic motion, with the amplitude calculated as 0.05 m.
  • Understanding of linear momentum and kinetic energy formulas
  • Knowledge of conservation of momentum in inelastic collisions
  • Familiarity with simple harmonic motion concepts
  • Ability to apply Hooke's Law and energy conservation principles
  • Review the principles of conservation of momentum in inelastic collisions
  • Study the relationship between kinetic energy and potential energy in harmonic motion
  • Learn how to derive the amplitude of oscillation from energy equations
  • Explore the derivation of the period of simple harmonic motion using angular frequency
Students preparing for physics exams, educators teaching mechanics, and anyone interested in understanding momentum and energy conservation in collisions and harmonic motion.
nyclio
I recently had a physics test and here are the questions that were given. I answered 3 out of 4. Would an expert please be able to tell me if I got them right or if not, please lead me in the right direction? I would wait to get my test back but that won't be for another 2 weeks and I am curious. Thanks in advance. :)
A 0.20 kilogram mass is sliding on a horizontal, frictionless air track with a speed of 3.0 meters per second when it instantaneously hits and sticks to a 1.3 kilogram mass initially at rest on the track. The 1.3 kilogram mass is connected to one end of a massless spring, which has a spring constant of 100 Newtons per meter. The other end of the spring is fixed.
A) Determine the following for the 0.20 kilogram mass immediately BEFORE the impact.
1. Its linear momentum:
p=mv
= (0.20)(3)
=0.6 kg*m/s
2. It's kinetic energy:
KE=0.5(mv^2)
=0.5(0.20)(9)
=0.9 J
B) Determine the following for the COMBINED MASSES immediately AFTER the impact.
p=(m1+m2)v
= (0.20+1.3)(3)
=4.5 kg*m/s
KE=0.5(m1+m2)(v^2)
=0.5(0.20+1.3)(9)
=6.75 J
After the collision, the two masses undergo simple harmonic motion about their position at impact.
C) Determine the amplitude of the harmonic motion.
I had no idea what to use for this?
D) Determine the period of the harmonic motion:
f=(1/2pi)*(sqrt(k/m1+m2))
T=1/f
=1/(1/2pi)*(sqrt(100/1.5))
=1/12.829 s
Any help on this is much appreciated!
Answers to A1 and A2 are correct. You have to recheck B1 and B2. The question asks for the momentum of the combined mass immediately after collision (ie just before the spring force starts to have an effect). That is determined by the initial momenta of the two masses. Having said this find the velocity. C asks for the maximum displacement of the masses on either side of equillibrium position. Use conservation of energy.
So for B1:
m1v1(initial)+m2v2(initial)=(m1+m2)v(final)
v(final)=(m1v1(initial))/m1+m2
=(0.20)(3)/1.5
=0.4 m/s
p=mv
=(1.5)(0.4)
=0.6 kg*m/s
B2:
0.5m1v1(initial)^2+0.5m2v2(initial)^2=0.5m1v1(final)^2+0.5m2v2(final)^2
0.5m1v1(initial)^2=0.5(m1+m2)v(final)^2
v(final)=1.095 m/s
KE=0.5(m1+m2)(v(final)^2)
=.891 J
Is this the answer for B1 and B2?
You're approach to the first one is right, but check you calculations.
As for B2, it's just 0.5M(v(final)^2); M = m1+m2.
B2 i see had the wrong calculations;
0.5M(v(final)^2)
It should come out to .899 J. But I double checked the calcuations for B1 - it still comes out to 0.4 - did I set it up incorrectly?
0.5M(v(final)^2)
Comes to .12 J with v=0.4m/s.
I believe you had typed 0.46 or something before I posted my previous reply. You had missed m2 in the denominator.
Oh yes - I had corrected the original post - question though - how come when I do v(final) using conservation of momentum and when i do it using conservation of mechanical energy - i come up with 2 different answers? You can see what I mean above - one answer gave me 0.4 m/s for vfinal (momentum) and the energy way gave me 1.095 m/s.
That's because you've assumed that kinetic energy is conserved. It is not conserved since this is a completely inelastic colission.
Arghh I totally forgot!
I am still unsure of questions C and D. Thanks for the help so far!
On the right track for D, but calculation needs checking, again. Check my first post for a hint for C.
1/2pi = 1.571
k/m1+m2 = 100/1.5 = 66.7
sqrt (66.7)= 8.167
1.571*8.167=12.829
T=1/f
=1/12.829 s
Where am i going wrong?
You've stated that 1/2pi > 1... Please go through the whole thing once again slowly. It's all calculation errors and I can show you where you've gone wrong, but that's not going to help you at all. Also remember the direct relation between time period and angular frequency.
3.14/2 = 1.57 - am i using the wrong value for pi?
frequency = angular frequency/(2pi) ... f = w/(2pi)
Time, T = 1/f = (2pi)/w
K=0.5kA^2
A=Sqrt(2K/k)
=Sqrt((2*0.12)/100)
=0.05 m
Is this correct? Thanks!
Likes lovehatephysics
