Undergrad Proving a Fixed Point Theorem for Shrinking Maps on Compact Spaces
A shrinking map f on a compact space X guarantees a unique fixed point. The discussion revolves around proving that if A_n = f^n(X) and A = ∩A_n, then any limit point a of the sequence y_n = f^n(x_n) lies in A. The participants clarify that since A_n is closed and compact, the limit a must also be in A. The argument hinges on showing that a belongs to A_m for all m, leading to the conclusion that A = f(A) and thus the diameter of A is zero. The theorem asserts that if a sequence converges, its limit is a fixed point of f.
facenian
TL;DR
A problem in Munkres' topology book ##\S##-7(b) Page 183
Show that if ##f## is a shrinking map ##d(f(x),f(y)) < d(x,y)## and ##X## is compact, then ##f## has a unique fixed point.
Hint. Let ##A_n=f^n(X)## and ##A=\cap A_n##. Given ##x\in A##, choose ##x_n## so that ##x=f^{n+1}(x_n)##. If ##a## is the limit of some subsequence of the sequence ##y_n=f^n(x_n)##, show that ##a\in A## and ##f(a)=x##. Conlude that ##A=f(A)##, so that ##diam\,A=0##.
Solution: I can prove all except that ##a\in A##, i.e., I had to assume it to prove that ##A=f(A)## and ##diam\,A=0##.
Any help will be welcome.
I will not bother working with a subsequence, and I'll take the full sequence. The easy modification to the general case is left to you.
You should show that ##a \in A_m## for all ##m \geq 1##. Note that we have a descending chain ##A_1 \supseteq A_2 \supseteq \dots##. Fix ##m \geq 1##.
Observe that ##y_n \in A_n \subseteq A_m## for ##n \geq m##. Thus
$$a = \lim_{n \to \infty, n \geq m} y_n \in A_m$$ because ##A_m## is closed (limits of sequences in a set remain in the closure of the set).
Since ##m \geq 1## is arbitrary, ##a \in \bigcap_{m=1}^\infty A_m=A##.
Many thanks for your response, however, I believe that it is not correct. Let us just work with the sequence as you said. Your answer would be correct if ##y_n\in A## then ##a## would be in ##\overline{A}=A##. The problem is that ##y_n\not\in A## in general because we cannot assume that ##y_n\in A_m## for ##m>n##, so ##a## is a limit point for the elements ##\{y_k:k\in Z^+\}## but not for elements in ##A##.
I never claim that ##y_n\in A##. Reread my answer more carefully please.
I don't show directly that ##a\in A##, I rather show that ##a \in A_m## for every ##m## and this follows because the sequence lives in ##A_m## for sufficiently large indices. Hence the limit lives in ##\overline{A_m}=A_m##.
You can do this for every ##m## and then you can conclude that ##a \in A##.
Could you let me know if this helped?
Likes facenian
You are right! I read it and interpreted it as I tried to solve it before. Thank you.
Likes member 587159
Each An is compact and therefore closed ( in a metric space) and thus so is A as the intersection, and complete ( compact subset/subspace of metric is complete).A Cauchy sequence in A must therefore converge to a point in A.
The sequence does not live in ##A##.
Yes, I clearly oversped on this one. Let me read more carefully.
Let ##(X,d)## be a metric space and let ##f:X\to X## be such that
$$d(f(x),f(y))<d(x,y),\quad x\ne y.$$
Theorem. Assume that for some ##x_0## a sequence ##x_{n+1}=f(x_n)## contains a convergent subsequence: ##x_{n_k}\to x_*##. Then ##f(x_*)=x_*##
Likes nuuskur
  • · Replies 17 ·
  • · Replies 0 ·
