A floating point Notation Exercise
The discussion focuses on calculating the minimum exponent value, e_min, for a 16-bit floating point binary notation to represent the numbers r = -8147.31 and s = 0.103 x 10^{-6}. The user outlines steps to determine the order of magnitude for both numbers, concluding that e_min must be at least 6 to accommodate the larger number, r. They also note that the representation of r requires more than 16 bits for accuracy, raising concerns about the feasibility of representing it within the specified limits. The conversation emphasizes the importance of understanding floating point notation and its constraints in numerical representation.
hastings
Consider a floating point binary notation with 16 bits. From left to right, it consists of 1bit for the sign (0= "+"), e bits for the exponent represented in Excess~2^{e-1} and the remaining bits for the decimal part of the mantissa, normalized between 1 and 2 (1 \leq m <2).
a) Calculate the minimum value e_{min} of the exponent that allows us to write in the above notation, both the numbers r= -8147.31 and
s= 0.103 \cdot 10^{-6};
This is what I would do.
1. Calculate the order of magnitude of both r and s
2. Write a proportion knowing that 2^{10} \approx 10^3 (like say 10:3= x: 4, considering 4 the result of point 1. ).
3. Find x from the above proportion and find the highest power of 2 which includes x (like say x=15, 2^3 \leq 15 \leq 2^4, I'd take 2^4)
4. Calculate e_{min}: since it's in excess 2^{e-1}, I solve the equation 2^4=2^{e-1} \Rightarrow e=e_{min}=4+1=5, where 2^4 is the result of point 3.
Is this resoning right?
Now, when I went to calculate the order of magnitude of r and s, I got that
Ord of Magn r=10^4, better say 4.
Ord of Magn s=10^{-5} better say -5.
Which should I consider as a starting point, 10^4 \mbox{ or } 10^{5} ?
Computer science news on Phys.org
hey, I really REALLY, need a help with this exercise, got an exam day after tomorrow.
got an idea: suppose I do the 1 to 4 steps for each of the numbers? In the end I see which one "includes" the other and I choose that one.
Let's do it.
Let's take r, its Order of magnitude is 4
10^4 \approx 2^{10} \Rightarrow 2^2 \leq 10 \leq \underbrace{2^3} \Rightarrow 2^3=2^{e-1} \Rightarrow e=3+1=4
Then take s, its O of M is -5 but since at the end what we get is the number of bits, which cannot be negative, we shall consider it simply 5.
This time we need to write a proportion about exponents:
since 2^{10} \approx 10^3 and we want to find the equivalent of 10^5=2^?
10:3=x:5 \Rightarrow x=\frac{10 \cdot 5}{3} \approx 17 \Rightarrow 2^4 \leq 17 \leq \underbraces{2^5} \Rightarrow 2^5=2^{e-1} \Rightarrow e=5+1=6
Since e=6 includes e=4, e_min =6.
So I suppose I should have taken 5 as the common order of magnitude for both the numbers in the decimal system.
Is what I just said a big bunch of nonsense?
Please reply asap!
Don't forget the common "cheat" used by most formats, where the first bit of the mantissa is assumed to be one and not included in the bits of a floating point number. You may have covered this case since you stated the mantissa represents a number between 1 and 2. In most floating point formats, the mantissa represents a number between >0 and <1. Reserved combinations of values are used for special cases, like all zero bits for zero.
However you've got a problem, 8147.31 takes more than 16 bits to represent to the nearest 1/100th.
Sorry I didn't get you.
The notation is
sign / exponent in Exc.2^{e-1} / mantissa norm. 1 & 2
1bit / e bits / (15-e) bits = Tot. 16 bits
example
suppose we find out e=6
and we want ot represent +1.0101 * 2^3 (doesn't matter what's its value)
exponent: since it's in Excess 2^(e-1), ==> 3 +(32) =35 (32 come from 2^(e-1)=2^5=32)
with 6 bits, 35 is 1 0 0 0 1 1 .
mantissa: 9 bits (=15-e=15-6) 0101 000 00
So ultimately the number in the above notation is
0 100011 010100000 (from left to right: 0 means it's positive, the following 6 bits are the exponent and the remaining 9 are the mantissa)
My point is that it takes 20 bits (or at least more than 19 bits) to represent 814731 x 10^? accurately.
Thread 'ChatGPT Examples, Good and Bad'
I've been experimenting with ChatGPT. Some results are good, some very very bad. I think examples can help expose the properties of this AI. Maybe you can post some of your favorite examples and tell us what they reveal about the properties of this AI. (I had problems with copy/paste of text and formatting, so I'm posting my examples as screen shots. That is a promising start. :smile: But then I provided values V=1, R1=1, R2=2, R3=3 and asked for the value of I. At first, it said...
  • · Replies 52 ·
  • · Replies 17 ·
