A floating point Notation Exercise
The forum discussion focuses on calculating the minimum exponent value (e_min) for a 16-bit floating point binary notation, specifically for the numbers r = -8147.31 and s = 0.103 x 10^{-6}. The calculations reveal that e_min must be at least 6 to accommodate both numbers, as the order of magnitude for r is 4 and for s is -5. The discussion emphasizes the importance of using the correct representation for the exponent in Excess 2^{e-1} and highlights that the mantissa must be normalized between 1 and 2. Additionally, it notes that representing 8147.31 accurately requires more than 16 bits.
  • Understanding of floating point binary notation
  • Knowledge of Excess notation for exponents
  • Familiarity with order of magnitude calculations
  • Basic arithmetic and proportional reasoning
  • Study the representation of floating point numbers in IEEE 754 format
  • Learn about the implications of mantissa normalization in binary systems
  • Explore the concept of precision and range in floating point arithmetic
  • Investigate how to calculate the required bits for various numerical values
Students preparing for exams in computer science, software engineers working with numerical computing, and anyone interested in understanding floating point representation in programming and hardware design.
hastings
Consider a floating point binary notation with 16 bits. From left to right, it consists of 1bit for the sign (0= "+"), e bits for the exponent represented in Excess~2^{e-1} and the remaining bits for the decimal part of the mantissa, normalized between 1 and 2 (1 \leq m <2).
a) Calculate the minimum value e_{min} of the exponent that allows us to write in the above notation, both the numbers r= -8147.31 and
s= 0.103 \cdot 10^{-6};
This is what I would do.
1. Calculate the order of magnitude of both r and s
2. Write a proportion knowing that 2^{10} \approx 10^3 (like say 10:3= x: 4, considering 4 the result of point 1. ).
3. Find x from the above proportion and find the highest power of 2 which includes x (like say x=15, 2^3 \leq 15 \leq 2^4, I'd take 2^4)
4. Calculate e_{min}: since it's in excess 2^{e-1}, I solve the equation 2^4=2^{e-1} \Rightarrow e=e_{min}=4+1=5, where 2^4 is the result of point 3.
Is this resoning right?
Now, when I went to calculate the order of magnitude of r and s, I got that
Ord of Magn r=10^4, better say 4.
Ord of Magn s=10^{-5} better say -5.
Which should I consider as a starting point, 10^4 \mbox{ or } 10^{5} ?
Computer science news on Phys.org
hey, I really REALLY, need a help with this exercise, got an exam day after tomorrow.
got an idea: suppose I do the 1 to 4 steps for each of the numbers? In the end I see which one "includes" the other and I choose that one.
Let's do it.
Let's take r, its Order of magnitude is 4
10^4 \approx 2^{10} \Rightarrow 2^2 \leq 10 \leq \underbrace{2^3} \Rightarrow 2^3=2^{e-1} \Rightarrow e=3+1=4
Then take s, its O of M is -5 but since at the end what we get is the number of bits, which cannot be negative, we shall consider it simply 5.
This time we need to write a proportion about exponents:
since 2^{10} \approx 10^3 and we want to find the equivalent of 10^5=2^?
10:3=x:5 \Rightarrow x=\frac{10 \cdot 5}{3} \approx 17 \Rightarrow 2^4 \leq 17 \leq \underbraces{2^5} \Rightarrow 2^5=2^{e-1} \Rightarrow e=5+1=6
Since e=6 includes e=4, e_min =6.
So I suppose I should have taken 5 as the common order of magnitude for both the numbers in the decimal system.
Is what I just said a big bunch of nonsense?
Please reply asap!
Don't forget the common "cheat" used by most formats, where the first bit of the mantissa is assumed to be one and not included in the bits of a floating point number. You may have covered this case since you stated the mantissa represents a number between 1 and 2. In most floating point formats, the mantissa represents a number between >0 and <1. Reserved combinations of values are used for special cases, like all zero bits for zero.
However you've got a problem, 8147.31 takes more than 16 bits to represent to the nearest 1/100th.
Sorry I didn't get you.
The notation is
sign / exponent in Exc.2^{e-1} / mantissa norm. 1 & 2
1bit / e bits / (15-e) bits = Tot. 16 bits
example
suppose we find out e=6
and we want ot represent +1.0101 * 2^3 (doesn't matter what's its value)
exponent: since it's in Excess 2^(e-1), ==> 3 +(32) =35 (32 come from 2^(e-1)=2^5=32)
with 6 bits, 35 is 1 0 0 0 1 1 .
mantissa: 9 bits (=15-e=15-6) 0101 000 00
So ultimately the number in the above notation is
0 100011 010100000 (from left to right: 0 means it's positive, the following 6 bits are the exponent and the remaining 9 are the mantissa)
My point is that it takes 20 bits (or at least more than 19 bits) to represent 814731 x 10^? accurately.
I am having a hell of a time finding a good all-in-one inkjet printer. I must have gone through 5 Canon, 2 HP, one Brother, one Epson and two 4 X 6 photo printers in the last 7 yrs. all have all sort of problems. I don't even know where to start anymore. my price range is $180-$400, not exactly the cheapest ones. Mainly it's for my wife which is not exactly good in tech. most of the problem is the printers kept changing the way it operate. Must be from auto update. I cannot turn off the...
  • · Replies 52 ·
  • · Replies 17 ·
