A little Bra-Ket notation theorem that I don't get
13 replies · 3K views
Excimer
I'm continuing through Dirac's book, The Principles of Quantum Mechanics. You can view this as a google book in the link below.
http://books.google.com.au/books?id=...page&q&f=false
On page 28-29 he proves this Theorem:
If ξ is a real linear operator and
ξm|P> = 0 (1)
for a particular ket |P>, m being a positive integer, then
ξ|P> = 0
And the proof is fine by me except for the first part where he says:
put m = 2 then (1) gives
<P|ξ2|P> = 0 (2)
and goes on to prove it by induction. But I don't see how (2) is 'given' from (1).
Can anyone explain?
If he is relying on assuming (1) is true for some ket |P> and positive integer m, then I just pick m = 1 and it's not a theorem. And besides, in this case he never demonstrates a definite example of the statement being true, which you need to do in induction.
By the way I do understand that because ξ is a real linear operator that the conjugate to ξ|P> is <P|ξ so that you can write <P|ξξ|P>, but I don't see that it follows this is equal to zero.
The assumption is that for some positive integer m, equation (8) holds.
Clearly, if m = 1 the statement is trivial, so he considers m = 2 as the base case.
So first he proves that if ξ²|P> = 0, then ξ|P> = 0. The reasoning is as follows: assume ξ²|P> = 0. <P| is a linear operator, so <P|0 = 0. Hence, <P|ξ²|P> = 0. However, instead of looking at that expression as <P| applied to ξ²|P>, you can also view it as <P|ξ applied to ξ|P>. Since ξ is real, <P|ξ = <P|ξ*, so what you have is really || ξ|P> ||² (the length of ξ|P>) which can only be zero if ξ|P> is zero.
Then he shows that if it is not given that ξ²|P> = 0 but ξm|P> = 0 for some higher m, it can be reduced to the m = 2 case from which we have just shown that the m = 1 case follows.
Compuchip,
So you mean to say that the theorem should specify m > 1 since otherwise you allow the trivial solution? It might be a silly detail but I find things more confusing when they are not stated rigorously.
In any case I think I get it now thanks to you.
It doesn't have to: it is also true for m = 1, but trivially so, as you say. However, if you want to prove it for all m then this case doesn't help you, so you need to consider m = 2 as the base case.
CompuChip said:
Good point.
It's been a while, wasn't it ξ|P> = <P|ξ?
So you need A = A := (A*)tr, in other words, for ξ to be Hermitian.
Yes, you need [itex]\xi[/itex] to be Hermitian. Or since [itex]\xi[/itex] is already real, you need it to be symmetric.
Or a little more general, if [itex]\xi[/itex] is normal (= commutes with its adjoint), then it holds. But it fails for more general operators.
If ξ is real then it equals it's own adjoint, and on page 28 Dirac remarks that if ξ is real than so is ξξ, so if you can take that at face value then ξ must commute with it's adjoint.
Ah, you got in before me.
Ok thanks both of you for helping me out.
Cheers
micromass said:
Oh, apparently Dirac uses the term "real linear operator" to mean "self-adjoint operator". In that case, the theorem holds true, of course. But it's a weird terminology...
Hi micromass,
Dirac wrote his QM book in 1930, before the terminology imposed in functional analysis through M.H.Stone's 1932 book appeared. He did review his QM book and 3 more editions appeared, but the mathematical terminology was not adjusted.
