Is it possible to eliminate back EMF in a transformer and achieve free energy?
  • Thread starter Thread starter p75213
    Transformer
The discussion centers on the possibility of eliminating back EMF in a transformer to achieve greater efficiency, with a proposed design involving a square or rectangular core structure. Participants debate the feasibility of this design, noting that while it may reduce certain losses, the fundamental principles of transformer operation suggest that back EMF is integral to energy transfer. The idea of achieving free energy through this method is dismissed as unrealistic, equating it to perpetual motion concepts. The consensus emphasizes that transformers are already highly efficient, and attempts to eliminate back EMF could lead to misconceptions about energy generation. Ultimately, the thread concludes with a warning against pursuing free energy theories, which are considered pseudoscience.
p75213
I have been reading about mag-amps which gave me an idea for a more efficient transformer.
So the core is in the shape of a square or rectangle with a center piece dividing it into two. The construction of the outer core is larger (less reluctance) than the middle leg (greater reluctance). The primary coil is wound on the center piece and the secondaries on the outer sides. The flux from the secondaries would tend to be confined to the outer periphery of the core with very little entering the center core (would it cancel?). In the same way that this method of construction eliminates the high voltage induced in the control winding of a mag-amp so to would it eliminate the back emf from the secondaries to the primary. So the primary would only have to supply the magnetizing current.
It would be nice to see a drawing.
Please consider that 'primary' and 'secondary' are about a technical approach: by physics a transformer is supposed to work both ways.
Well think of a capital 'E' turned on its side with a connecting piece across the top. The primary coil is wound on the center leg and the secondaries wound on the two end legs. This transformer would only work one way.
That's usually called EI core.
That's like getting a negative weight for a car after doing the math for the homework: you can be sure that you missed something.
Consider this: the starting point for transformer efficiency is that the more magnetic flux created by one of the coils goes through the other coil, the better. And there is no 'primary' or 'secondary' in this...
Rive said:
That's usually called EI core.That's like getting a negative weight for a car after doing the math for the homework: you can be sure that you missed something.
Surely if you only have to maintain the magnetizing current that creates the magnetic flux that has to be efficient.
Copper loss
Eddy currents
Hysteresis
Stray loss
Mechanical loss and magnetostriction
I’m not the one to answer your question, but transformers are generally highly efficient anyway. Which of the above would your design reduce? Stray loss? You are chipping away at a very small piece of inefficiency, and a small part of that, too. Interesting, though.
Likes berkeman and russ_watters
Problem: not all the flux from the primary would pass through one of the secondaries. That means the coupling between primary and each secondary would be really poor. Magnetic circuits are a bit like electrical circuits and an alternative path for the magnetic flux is a bit like a leakage path across a battery terminals. The battery power would be wasted.
I have done a bit of reading on saturable core reactors in the past. Do a little research, you will find winding configurations similar to what you describe already exist.
Guineafowl said:
Copper loss
Eddy currents
Hysteresis
Stray loss
None of the above. The idea is to remove the back emf from the secondary to the primary. The result of doing this is to reduce, if not cancel, the increase in amperage draw from the source due to the load on the secondary. Effectively the source only has to supply enough current to maintain the magnetic field in the primary (magnetizing current), no matter the load on the secondary.
That sounds too much like getting energy from nowhere, which doesn't happen too often.
Likes CalcNerd, russ_watters and berkeman
Are they efficient though? Which was the initial question.
Oh dear, I just saw this. I guess I need to go back and read the whole thread. Wait one...
UPDATE -- Thread closed for Moderation...
What you are proposing and pursuing is Free Energy, and we don't waste folks time discussing such things here. In this case, it is enveloped in electronics fundamentals, but it is the same as if you were proposing a perpetual motion machine (PMM) waterwheel.
The back EMF is part of the normal transformer action that transfers energy from the source to the load. To try to eliminate the back EMF is basically the same as trying to create Free Energy.
I learned about PMMs and Free Energy when I was about 12 years old, when I drew up plans for a jet backpack and showed them to my father. I had an intake turbine coupled to an output turbine -- the intake turbine generated thrust, and the output turbine recovered the energy to supply back to the input turbine. My dad patiently explained PMMs and Free Energy to me then, and I was able to understand why such things are not possible.
And we provide links in the PF rules to help folks figure this stuff out without wasting forum electrons on such discussions:
Forbidden Topics said:
Pseudoscience, such as (but not limited to):
Perpetual motion and "free energy" discussions
http://en.wikipedia.org/wiki/Perpetual_motion
http://www.skepdic.com/freeenergy.html
http://www.skepdic.com/perpetual.html
Thread will remain closed.
Likes CalcNerd and davenn
  • · Replies 36 ·
12K
