A multiplication map as a matrix in Q(sqrt2)
3 replies · 3K views
Gale
Consider the field [itex]Q(\sqrt{2})[/itex], viewed as a vector space of dimension 2
over [itex]Q[/itex]. Let [itex]r + s\sqrt{2} \in Q(\sqrt{2})[/itex], and defi ne the multiplication map
[itex]M_{r+s\sqrt{2}}: Q(\sqrt{2}) → Q(\sqrt{2})[/itex] by [itex] M_{r+s\sqrt{2}}(\alpha)= (r+s\sqrt{2})*\alpha[/itex]
In other words, [itex]M_{r+s\sqrt{2}}[/itex] is multiplication by [itex]r+s\sqrt{2}[/itex]
There's a few parts, but my linear algebra is really rusty, so I can't even figure out the first step:
(i) In terms of the basis [itex]\{1, \sqrt{2}\}[/itex] express the Q-linear map [itex]M_{r+s\sqrt{2}}[/itex] as a 2x2 matrix with entries in Q.
(ii) If [itex]A[/itex] is a 2x2 matrix with entries in Q, what is the condition that [itex]A=M_{r+s\sqrt{2}}[/itex] with respect to the matrix?
(iii) What is the determinant? Argue without computation that it's not zero.
(iv) Calculate the inverse matrix and show that it is of the form [itex]M_{t+u\sqrt{2}}, t,u \in Q.[/itex] Use this to give an explicit formula for [itex](r+s\sqrt{2})^{-1}[/itex]
I honestly have no idea how to express the linear map as a matrix, and the rest of the problem basically hinges on that concept. The only part I think I understand is that because the vector space has dimension =2, it's going to have 2 elements in it's basis? And thus a 2x2 matrix? But I'm not even exactly sure I have that right...
So just trying to figure out what this is talking about...
I guess α is some element of the form α= a+b√2, for some a and b in Q, right? So if I just multiply out the function...
[itex]M_{r+s\sqrt{2}}(\alpha)= (r+s\sqrt{2})*\alpha= (r+s\sqrt{2})*(a+b\sqrt{2})= (ar+2bs)+\sqrt{2}(as+br)[/itex]
So the matrix should produce the same result if I do [itex]\alpha*A[/itex] right? So... I suppose that means my matrix would be (r s,2s r)?
(sorry I don't remember how to format matrices)
over [itex]Q[/itex]. Let [itex]r + s\sqrt{2} \in Q(\sqrt{2})[/itex], and define the multiplication map
It depends a bit on whether you want to picture the vector representing ##\alpha## as a column vector and let A act on the right, so the result is ##A \alpha## or have ##\alpha## be a row vector and act on the left, so it's ##\alpha A##. You've got the right matrix for the last case. If it's the first case you just need to take the transpose.
Ah thank goodness I figured something out! Would ##A \alpha## be the more proper way of writing it out then?
Since I have that, for the rest:
(ii) if [itex]A= \left( \begin{array}{ccc}<br /> a & b \\<br /> c & d \end{array} \right)[/itex] Then based on my matrix from part (i), a=d and 2b=c would work? Or does a also have to be a multiple of r, and b a multiple of s?
(iii) I'm a little confused about this... I guess since the determinant would be r2-2s2 and r,s are rational by definition, r2-2s2=0 would imply r2=2s2 → √2 is rational if both s,r≠0. Which is equivalent to saying r+s√2=0. I'm not sure if what I did counts as calculation.
(iv) The inverse is found in the traditional way for a 2x2, but I'm not really sure how it gives me (r+s√2)-1
##A \alpha## is probably more common. In which case a matrix [itex]A= \left( \begin{array}{ccc}<br /> r & 2s \\<br /> s & r \end{array} \right)[/itex] will do the job. For iii) you've got it. If r and s are rational then the only noninvertible matrix is zero because the square root of 2 is irrational. For (iv) if you find the inverse matrix style and then convert back to r and s you should get the same thing as the matrix of (r+s√2)^(-1), shouldn't you?
