A naive question about irrational numbers
The discussion revolves around the nature of irrational numbers, measurement, and the relationship between mathematical concepts and physical reality. Participants explore the implications of measuring lengths in a theoretical right isosceles triangle and the challenges of achieving exact measurements in the physical world.
  • One participant questions whether measuring the hypotenuse of a right triangle formed by two 1-meter rods would yield a rational number, given that the hypotenuse is mathematically √2.
  • Another participant argues that mathematical triangles do not perfectly represent physical triangles, suggesting that mathematics elucidates logical structures rather than describing reality.
  • Some participants discuss the implications of measurement error and the idea that any difference from the mathematical hypotenuse is due to inaccuracies in measurement rather than a flaw in the mathematical model.
  • There is a debate about the concept of "exact" measurements, with some asserting that no physical measurement can be exact due to the limitations of measuring tools and the nature of physical objects.
  • One participant introduces the idea of unit cells in chemistry to explain how irrational numbers can be relevant in physical contexts, suggesting that irrational numbers can represent quantities in atomic structures.
  • Another participant raises the question of whether space is continuous or discrete, linking it to the challenges of measuring exact distances.
Participants express differing views on the relationship between mathematical ideals and physical measurements. There is no consensus on whether exact measurements can be achieved in reality, and the discussion remains unresolved regarding the implications of irrational numbers in practical applications.
Participants highlight limitations in measurement due to the nature of physical objects and the tools used for measurement. The discussion also reflects on the idealized nature of mathematical constructs compared to real-world applications.
  • #31
la6ki said:
I see.
If space is in fact continuous, can we then talk about exact physical lengths in terms of space?
We can talk about exact physical lengths in the abstract, but as you have been told several times in this thread, there is no way to measure them exactly.
Mathematics news on Phys.org
  • #32
Hmm, sorry if I offended you somehow, didn't mean to be rude.
  • #33
las6ki,
Take the length of a rod. By rod, I take it you mean some type of long cylinder.
In math we take things to be perfect, because it makes thing nice. So in a math world, the cylinder has a length, because the circle on the top and bottom of the cylinder are perfectly flat, and the cylinder is perfectly straight.
A rod in the real world can never be. As you pointed out before the rod in the real world would be made of atoms. So consider the top and the bottom of your rod. It is akin to a petri dish full of different sized marbles.
Now what is length? Do we measure from the tallest marble? or do we measure from the average height of the marbles?
How do we determine if in fact the rod is perfectly straight? It is not solid in the same sense the mathematical cylinder is? Indeed at an atomic level there is space between the atoms.
Objects in a mathematical world like a cylinder can be kind of like objects in the real world. However they are not.
I hope I have helped.
  • #34
I'm sorry if this has already been said, but I'd like to point out that the [itex]\sqrt{2}[/itex] is in fact a real number.
Assuming for a minute that we had the tools of perfect accuracy and precision to be able to actually measure the given idealized distances (the difficulty of which has already been discussed), this number is as much able to found ([itex]\sqrt{2}[/itex]) as 3 or 17 using a real-world number line a.k.a a measuring stick.
To maybe express an irrational number as a quantity of some fixed indivisible item is another matter altogether (i.e., [itex]\sqrt{7}[/itex] marbles).
I guess we also have to analyze what we mean by the word "measure." We really want to be able to measure arbitrary distances based on a defined fixed unit of continuous space. Unfortunately, we have no way of doing this without using a reference -- which then leads our measurement to be a multiple of that fixed reference (e.g., the number of atoms in a meter stick to get us to 1 cm), which leads us back to having a hard time with irrationals.
I got to the end of this not feeling as confident in my explanation as I did before I typed it, so I hope it at least helped a -small- bit.
  • #35
I just saw your responses, guys. Thanks, they both make things clearer for me :) I still feel like there are a few things that need some clarification, but I'll ask when I can formulate them better.
  • #36
Every REAL measurement has associated with it error bounds. Generally you can take your error to be 1/2 of the smallest division on your measuring instrument.
So your 1 m rod by measurement is 1m +/- Δ, where the magnitude of Δ is determined by your measurement instrument. Note that in the real world a device which will measure 1m to +/-.1mm is a specialty device which will cost you a good sum of money.
No matter how you do the measurement there will always be uncertinaty. That is why you cannot have a real rod exactly 1m. It may be, you just cannot prove it.
Your measurement of the √2 length will have the same errors, so the fact that √2 is irrational is immaterial, its length is known only as good as your ability to measure. Measuring any length to more then 3 or 4 decimal places is essentially impossible for the man on the street.
  • · Replies 28 ·
  • · Replies 38 ·
  • · Replies 30 ·
  • · Replies 39 ·
