Homework Helper
- 2,180
Sorry, the "filtering hypothesis" is theoretically and factually incorrect, and this has even been experimentally demonstrated as such.Fra said:1. The final correlated 1&4 pairs are not even defined until Chris has tagged the matches and communicated to Alice and Bob so they can "filter" the random pairs.
The fact that 1&4 has never been in contact, does not matter because it's not how the remotely entangled systems are constructed.
They are constructed from two independently entangled pairs, and whose mutual "correlation" is CREATED from "filtering" based on the tag info from Chris. This is pure information processing, this is why there is no non-nocal action needed. This filtering can be done at any point in time, which is why order does not matter. But what does matter is that that info from swap tagging at Chris, must be available, otherwise one can never identify the entangled remote pairs [as being ψ+ or ψ-].
First, all 2 & 3 pairs that fit within the time window of the BSM lead to entanglement of 1 & 4 into one of the 4 Bell states. There is no filtering happening; if there are 2 near-simultaneous clicks at the BSM, there is a swap.
There cannot be a hidden correlation between the 1 & 4 pairs waiting to be revealed, since they are independently prepared. It should be obvious that the 1 & 4 photons - from fully independent sources - yield random outcomes which cannot be independently sorted into buckets using a coding mechanism that does not exactly reveal the same information as Alice and Bob obtain in the first place. In other words: Chris would need to perform the same experiment on 2 & 3 as Alice and Bob do on 1 & 4 to obtain the information you imagine. That isn't being done by Chris. (And in fact there is some polarization information being obtained by the BSM; but since it is always either |HV> or |VH> it is itself useless.) And it wouldn't lead to entanglement of 1 & 4 if that's what Chris did. It would be classical (and couldn't even violate a Bell inequality, since there would be Product State statistics).
Besides, in many of the swapping experiments: the orientations that Alice and Bob are measuring are selected mid-flight. It is done too late for there to be any light speed communication between the various observation stations. See this important swapping experiment in which independent random number generators are used for the Alice and Bob observations.
Second: Were what you said true, then why does indistinguishability even matter? By your concept, all that Chris does with the Bell State Measurement (BSM) is reveal whether we have ψ+ or ψ-. You even say it is pure information processing. Well guess what, you can obtain that exact same information - i.e. the markers indicating ψ+ or ψ- - even without indistinguishability. But... no indistinguishability, no entanglement! The marker for ψ+ is simultaneous clicks on the |H> and |V> detectors by the same output port of the beam splitter portion of the BSM. The marker for ψ- is simultaneous clicks on the |H> and |V> detectors by different output ports of the beam splitter portion of that BSM.
This particular point was analyzed and tested in this swapping experiment. From the paper (and note that this particular experiment looks at the 2 φ Bell states instead of the 2 ψ Bell states):
"One can also choose to introduce distinguishability between the two projected photons. In this case, the phase between the two terms of the |φ> projected state is undefined, resulting in a mixture of |φ+> and |φ−> in the projected state, and the first and last photons do not become quantum entangled but classically correlated. We observed this when we introduced a sufficient temporal delay between the two projected photons (see Fig. 3c). It is also evidence that the first and last photons did not somehow share any entanglement before the projection of the middle photons."
If the BSM is just filtering - and there is no remote physical projection occurring - then this result should not occur.
Third: the "filtering hypothesis" implies that any 2 entangled photons arriving within the coincidence window of the BSM would have their entangled partners containing "hidden" correlations waiting to be revealed. There cannot be sunc hidden maximum entanglement - pre-existing and waiting to be revealed - between 3 photons without violating Monogamy rules. The BSM must be successful as a physical process to cause the entanglement swap.
To quote the earlier reference from the team of Kaltenbaek et al:
"A successful entanglement swapping procedure will result in photons 1 and 4 being entangled, although they never interacted with each other. ... We confirm successful entanglement swapping by testing the entanglement of the previously uncorrelated photons 1 and 4."
