Finding the Perfect Value of k for a Square Trinomial
  • Thread starter Thread starter soggybread
    Square
The value of k that makes the expression 25x² - 60xy + ky² a perfect square trinomial is determined by the condition that the discriminant must equal zero. By setting up the equations A² = 25x², 2AB = -60xy, and B² = ky², we find that k must equal 36. This conclusion is reached by substituting the values into the discriminant formula, resulting in the equation 60² = 4 * 25 * k, which simplifies to k = 36.
  • Understanding of perfect square trinomials
  • Familiarity with quadratic equations
  • Knowledge of discriminants in algebra
  • Basic algebraic manipulation skills
  • Study the properties of perfect square trinomials
  • Learn about the discriminant and its role in determining the nature of roots
  • Explore quadratic equations and their factorizations
  • Practice solving for coefficients in polynomial expressions
Students learning algebra, educators teaching quadratic equations, and anyone interested in mastering polynomial factorization techniques.
soggybread
ok, I'm pretty sure this is ridiculously simple, but I am stumped by this question..
What value of k would make 25x^2 - 60xy + ky^2 a perfect square trinomial?
I just don't know where to begin in order to find k. :rolleyes:
Any help would be much appreciated!
Ok well starting with a binomial (A + B)
then (A + B)2 = (A + B)(A + B) = A2 + AB + AB + B2
which is the same as
A2 + 2AB + B2
Which would be a perfect square trinomial so do you think you could right the trinomial in question in this form for some value of k?
Just a tiny bit more help: as d leet said, a perfect square must be of the form (A+ B)2= A2+ 2AB+ B2.
Your formula is 25x2- 60xy+ ky2. That means you must have A2= 25x2, 2AB= -60xy and B2= ky2. From the first equation it should be obvious what A. Use that in the second equation to determine B and then use the third equation to find k.
Easy method - This is a perfect square. So discriminant must be 0. Put y = 1, so that this becomes a quadratic in x if you don't understand to usewhat I am talking about in the first statement. And I don't think this is a bad method.
So you would get 60^2 = 4*25*k.
Moreover here the value of y does not matter if you look deep. The co-efficient of first power of x is 60y and the constant is ky^2
So (60y)^2 = 4*25*k*y^2.
Ah! Thank You Guys! I see how it works now! :rolleyes:
  • · Replies 21 ·
  • · Replies 18 ·
