A problem on concurrent forces in a plane.
  • Thread starter Thread starter Monsterboy
    Forces Plane
3 replies · 5K views
Monsterboy
[/B]
A ball rests in a trough as shown in figure. Determine the angle of tilt ##\theta## with the horizontal so that the reactive force at B will be one-third at A if all surfaces are perfectly smooth.
2.Relevant equations
Application of Lami's theorem and some algebra and geometry
3.The attempt at a solution
I tried to derive an relation between ## \theta ## and the Ratio between the reactions Ra and Rb ,so at ##\theta## =00 the ratio between the reactions is one and at a particular ##\theta## the ratio becomes 3. The relation goes like this ##f(\theta) = x\frac{Ra}{Rb} ## where ##x## is a constant
This didn't lead me anywhere because there are too many unknowns.
Another equation i can think of is ##\theta ##= x(Ra-Rb) so at ##\theta =0 ## , Ra =Rb at what ##\theta## will Ra=3Rb?? The required angle ##\theta= x(2Rb) ## and ##x= \frac{\theta}{2Rb}##
I don't see this going anywhere either.
Is this the right way to go ?
Monsterboy said:
°°[/B]
I don't see why you can't draw a FBD of the ball and set up the normal forces on each contact surface using the conditions of static equilibrium.
Remember, the angle θ must be incorporated into the angle of the trough measured w.r.t. the bottom of the wedge. When θ = 0, then these angles will both be 30° as indicated on the diagram.
Thanks ,i took a little more time than expected to incorporate the angle since i had to imagine the thing to rotate ,i got the answer 16.13 degrees ,is there anyway to derive an equation like the one i mentioned ? i am just trying to find some alternative methods( if there are any).
I doubt it, since the answer, I think, depends on the trigonometry of the situation, which is not linear.
