A Projectile motion problem, I .
The problem involves projectile motion, specifically analyzing the firing of two cannon shells at different angles and determining the time interval between their firings that leads to their collision. The context includes neglecting air drag and using given equations for range and time of flight.
  • Participants discuss the time of flight for each shell and propose equating the time of flight with an assumed time interval to find the required interval for collision.
Some participants have suggested methods for determining the time interval, while others have expressed confusion regarding the problem setup. There is an ongoing exploration of the relationship between the time of flight and the interval between firings.
Participants note the need to clarify assumptions regarding the time of flight and the conditions for collision, as well as the potential misunderstanding of the problem's requirements.
a.ratnaparkhi
A cannon fires successively two shells with velocity u=250 m/s;the first at angle [tex]\theta1[/tex]=[tex]\pi/3[/tex] & the second shell at an angle [tex]\theta2[/tex]=[tex]\pi/4[/tex] to the horizontal, the azimuth being same. Neglecting air drag, find the time interval between firings leading to colling of shells.
range R=(u^2sin2[tex]\theta[/tex])/g
Time of flight t=(2usin[tex]\theta[/tex])/g
I'm really confused &unable to figure out.
Book says that its 11s.
Find the horizontal distance where the two bodies collide by solving there equations. From this, you can get time of flight of two bodies from projection to collision and what you need..?
I thought, if we assume the required time interval 't' and time of flight of two shells T1& T2 respectively, then after equating T1+t=T2, 't' can be easily found.
No...that would be the time between firings to get the shells to hit the ground simultaneously.
  • · Replies 18 ·
  • · Replies 22 ·
28K
