A question about numerical series
  • Thread starter Thread starter nernstkizen
    Numerical Series
The discussion revolves around the convergence of the series \(\sum \frac{a_n}{1+n a_n}\) given that \(\sum a_n\) diverges. Participants suggest using convergence tests, but some believe direct application of these tests may not be feasible without additional techniques. There is a consensus that the behavior of \(a_n\) as \(n\) approaches infinity is crucial in determining the convergence or divergence of the new series. Examples are provided to illustrate that the series can either converge or diverge depending on the specific form of \(a_n\). Ultimately, the conclusion is that the series can exhibit both behaviors based on the chosen sequence \(a_n\).
nernstkizen
suppose an>0, \sumandiverges
then what can we say about \sum an/1+nan
I think it divergent, but I'm not sure。
Hey nernstkizen and welcome to the forums.
Have you looked at tests for convergence (like ratio test) to get some ideas of how to possibly show this? What have you thought about or tried?
hi~
I think it is impossible to use any test to solve it directly, maybe some tricks should be introduced.
btw, it is the exercise 3.11(d) of Principles of Mathematical Analysis (Rudin). Some solutions said that it can either converge or diverge, but I don't agree with them.
nernstkizen said:
hi~
The thing I was thinking of is to use the facts about series that diverge.
For example if a series diverges then by the ratio test (assuming all positive numbers), the ratio between successive terms (an+1/an) must be greater than 1. Similarly you get other kinds of results that you can use.
The idea is to get as many of these results as possible and then incorporate them into your new series: you know that an+1/an > 1 in the ratio test so if you can re-arrange your ratio test in the second way to get this term then you can replace with some variable which is greater than 1.
nernstkizen said:
suppose an>0, \suman diverges .
then what can we say about \sum an/1+nan ?
I think it's divergent, but I'm not sure。
Do you mean \displaystyle \sum \ \frac{a_n}{1+n\,a_n}\ ? That could be written as \sum an/(1+nan) .
What you wrote literally means \displaystyle \sum \ \frac{a_n}{1}+n\,a_n\ .
As to whether \displaystyle \sum \ \frac{a_n}{1+n\,a_n}\ diverges or converges, that may depend upon the behavior of an as n → ∞ .
You can rewrite your series as \displaystyle \sum \ \frac{1}{(1/a_n)+n}\ .
What you wrote literally means \displaystyle \sum \ \frac{a_n}{1}+n\,a_n\ .As to whether \displaystyle \sum \ \frac{a_n}{1+n\,a_n}\ diverges or converges, that may depend upon the behavior of an as n → ∞ .
Thanks for your reply !:-p
1 What I mean is \sum \frac{a_n}{1+na_n}
2 I have already transformed it to \displaystyle \sum \ \frac{a_n}{1+n\,a_n}\ ,
and I think it won't converges as long as \sum an diverges as n\rightarrow∞
1 What I mean is \sum \frac{a<sub>n</sub>}{1+na<sub>n</sub>}
and I think it won't converges as long as an diverges as n\rightarrow∞
Do you mean the sequence, an, diverges, or do you mean the series, \sum an , diverges ?
Sorry, a typo.
I mean \sum an diverges.
I'm far from an expert on series nernstkizen, but I tend to think you're correct that it always diverges. My reasoning is as follows.
Consider the limiting value of just the n \, a_n part of the expression (as n goes to infinity). It may either,
1. go to zero.
2. remain bounded (say bounded by M).
3. go to infinity.
In case one, the tail of the new series approaches that of the original. So the series diverges.
In case two, the terms in the tail of the new series are bounded below by a constant multiple, 1/(1+M), of the original series. So again it diverges.
And in the third case, the terms of the tail of the series approaches 1/n. So again it diverges.
This series can both converge and diverge. Taking a_{n} = \frac {1} {n}, both series diverge.
Now take a_{n} = 1, if n = 2^{q} - 1 and a_{n} = 0, otherwise.
\sum a_{n} diverges because it sums infinitely many 1's.
\sum \frac {a_{n}}{1 + na_{n}} = \sum 0 + \sum \frac {1}{2^{q}} = 2
Oops, I missed the requirement a_{n} &gt; 0. But the proof can be trivially modified to account for that and have the series converge. Can you see how?
Thank you so much!
I get it :-p
Good example, thanks for posting that voko. :smile:
I was having trouble seeing how it could converge, as I was looking at it with "blinkers" on and only thinking about series that were monotonic in the tail.
  • · Replies 48 ·
