A question about the special case of calcium hydroxide
Calcium hydroxide (Ca(OH)2) is classified as a strong base despite its limited solubility in water, due to its high dissociation constant (K_B). The distinction between solubility and dissociation is crucial; solubility is defined by the solubility constant, while dissociation is characterized by the dissociation constant. The net ionic equation for the neutralization reaction between Ca(OH)2 and a strong acid is represented as OH- (aq) + H+ -> H2O (l), emphasizing the role of hydroxide ions in the reaction.
  • Understanding of acid-base chemistry
  • Familiarity with dissociation constants (K_B)
  • Knowledge of solubility constants
  • Basic grasp of net ionic equations
  • Research the differences between solubility and dissociation constants
  • Study the concept of strong vs. weak bases in detail
  • Learn how to derive net ionic equations for various acid-base reactions
  • Explore the implications of pH levels in relation to base strength
Chemistry students, educators, and professionals in the field of chemical education or research who seek to deepen their understanding of acid-base behavior and the properties of hydroxides.
Dong Aleta
Hi!
I am having trouble understanding how a substance only slightly soluble in water is considered as a strong base. Isn't the definition of a base a substance that will increase the amount of OH- in a solution? In that case, shouldn't calcium hydroxide be considered a weak base because of its limited ability to dissociate into Ca+ and OH- ions? Can someone explain this please?
I am seeking to understand this because I don't know how to express the net ionic equation for the acid-base neutralization involving Ca(OH)2 and a strong acid.
Will it be:
Ca(OH)2 (aq) + 2H+ (aq) -> Ca2+ (aq) + H2O (l)
or just simply:
Thanks so much!
Chemistry news on Phys.org
Solubility and dissociation are two different things. One is described by solubility constant, the other one by dissociation constant. Whether a base is a strong base, depends solely on the dissociation constant K_B.
Ah, of course! I get it now. Thanks a lot for pointing that out. I really appreciate the help!
Sorry, I'd like to add a follow-up question. I just came across this web page that said "Not all hydroxides are strong bases since not all hydroxides are highly soluble" suggesting that solubility has something to do with the basicity of the substance. Is the web page incorrect with its statement?
Here is a link to that web page: http://ch302.cm.utexas.edu/chemEQ/ab-theory/selector.php?name=strong-bases#q1b
Thanks so much!
Well, there are simply several way to judge the strength of a base. Either via the K_B or via the maximal pH you can reach. Hence talking about the strength of a base in plain language, this may sometimes be ambiguous.
I see! Thank you again for the response! Much appreciated!
11K
