A question for Sakurai's advanced qm
  • Thread starter Thread starter kof9595995
    advanced Qm
The discussion revolves around the transformation of the 4-component wave function in Sakurai's "Advanced Quantum Mechanics." There is confusion regarding how the space-time coordinates transform under the operator S, which is defined to act on the spinor part of the wave function. Participants clarify that while S transforms the spinor, the space-time coordinates also change according to Lorentz transformations, leading to the equation ψ'(x') = Sψ(Λ⁻¹x'). The transformation is viewed as both an active transformation on the wave function and a change of reference frame. The conversation highlights the complexity of understanding these transformations in quantum mechanics, particularly for spinors compared to vectors.
kof9595995
On page 96, he defined \psi'(x')=S\psi(x), but it seems what he later derived for S only transforms the spinor part not the space-time coordinate of the 4-component wave function, then how is the space-time coordinate primed after acted by S? I'm pretty sure it's not a typo according to what he did on page101, eqns (3.158)~(3.161).
I had Sakurai's advanced qm a few month ago.
But now I don't. Sorry, I imagine from your sentence.
First, Dirac's solution includes exponential function
\psi = \int_{-\infty}^{\infty} \frac{d^3 p}{\sqrt{2E_p}} a_p u(p) e^{-ipx} \cdots
Here, both the p (momentum, energy) and x (time , spece) are 4 vectors.
So "px" means scalar (= vector x vector). (px doesn't change under Lorentz transformation.)
And the integration of p is from -infinity to +infinity, so the change from p to p' is meaningless.
But of course, the differentiation by time and space coordinate in Dirac equation changes under Lorentz transformation ( x' = a x ).
\frac{\partial }{\partial x'_{\mu}} = \sum_{\nu} \frac{\partial x_{\nu}}{\partial x'_{\mu}} \frac{\partial}{\partial x_{\nu}} = \sum_{\nu} a_{\mu \nu} \frac{\partial}{\partial x_{\nu}}
So under Lorentz transformation, Dirac equation becomes
(-i\hbar \gamma^{\mu} \partial_{\mu}' + mc) \psi' (x') = (-i\hbar \gamma^{\mu} a_{\mu\nu} \partial_{\nu} + mc) S \psi (x) = (-i\hbar \gamma^{\mu} \partial_{\mu} + mc) \psi (x) =0
Is this what is discussed here ? (If not, I transfer your question to someone with advanced qm.)
I won't have access to my copy of Sakarai until tomorrow. Is S the 4-component spinor versionof a Lorentz transformation L? If so, then x' = Lx and
<br /> \begin{align}<br /> \psi \left( x&#039; \right) &amp;= S \psi \left( x \right) \\<br /> \psi \left( Lx \right) &amp;= S \psi \left( x \right) \\<br /> \psi \left( x \right) &amp;= S \psi \left( L^{-1} x \right)<br /> \end{align}<br />
George Jones said:
I won't have access to my copy of Sakarai until tomorrow. Is S the 4-component spinor versionof a Lorentz transformation L? If so, then x&#039; = Lx and
Yes, S is purely written in terms of gamma matrices and parameters like angle and rapidity, and the expression came into my mind first was \psi&#039;(x&#039;)=S\psi({\Lambda}^{-1}x)
George Jones, I want to confirm this equation.
According to p.60 of an introduction to quantum field theorey by Peskin, Dirac field change under Lorentz transformation,
\psi (x) \quad \to \quad \ \psi&#039; (x) = \Lambda_{1/2} \psi (\Lambda^{-1} x) \quad (S = \Lambda_{1/2}) \quad ( x&#039; = \Lambda x )
Changing x to x', this meaning is the same as
\psi&#039; (x&#039;) = \Lambda_{1/2} \psi (x) = S \psi (x) \qquad ( x = \Lambda^{-1} x&#039;)
S includes gamma matrices, so I think the form of psi changes under Lorentz trandformation.
Sorry. the next equation is what you mean ?
\psi&#039; (x&#039;) = S \psi (\Lambda^{-1} x&#039;) = S \psi (x) \quad or \quad \psi&#039; (x) = S \psi (\Lambda^{-1} x) \qquad x&#039; = \Lambda x \quad ( x = \Lambda^{-1} x&#039;)
Ah..I see where my problem is, I was thinking \psi&#039; (x) = S \psi (\Lambda^{-1} x), which means an active transformation acting on the wavefunction not the reference frame, so \psi&#039; (x&#039;) = S \psi (\Lambda^{-1} x&#039;) = S \psi (x) means Sakurai transformed both the reference frame and the wavefunction? That's weird, why did he do this?
I think it is easier to imagine "vector" ( ex, 4-vector potential A(x) ) instead of spinor, first.
A^{\mu} (x) = ( A^0 (x), A^1 (x), A^2 (x), A^3 (x) ) \qquad x^{\mu} = (x^0, x^1, x^2, x^3)
This 4-vector A (x) means that there is a thing " vector A " at the position of x ( from the viewpoint of reference frame K ).
Here we can consider 4-vector A as an thing such as "arrow".
So there is one "arrow" ( which vector direction is (A0, A1, A2, A3) ) at the coordinate of ( x0, x1, x2, x3 ) in the reference frame of K.
From the viewpoint of a different reference frame K', the position of the "arrow" changes (under Lorentz transformation),
x&#039;^{\mu} = \Lambda^{\mu}_{\nu} x^{\nu} \quad ( x&#039; = \Lambda x ) \qquad x&#039;^{\mu} = ( x&#039;^0, x&#039;^1, x&#039;^2, x&#039;^3 )
This means that from this reference frame K', the "arrow" exists at x'.
( x' from K' originally exists at x from K. )
How do we see the direction of this arrow from this reference frame K' ?
A is 4-vector, so this direction changes as 4-vector,
A&#039;^{\mu} = \Lambda^{\mu}_{\nu} A^{\nu} \quad ( A&#039; = \Lambda A )
As a result, from the reference frame K', there is an arrow which direction is A' at the coordinate of x'. So,
A&#039;^{\mu} (x&#039;) = \Lambda^{\mu}_{\nu} A^{\nu} ( \Lambda^{-1} x&#039; ) \qquad x = \Lambda^{-1} x&#039;
In the case of spinor, the position (= x ) of spinor changes as 4-vector, which is the same as that of vector A above.
But the change of "spinor direction" is different from the vector A.
( As you said, we use "S" instead of "Lambda" )
Thanks, your explanation is very clear. I just get confused every now and then on this issue, now i get the moment of clarity, but probably someday I'll get confused again: (
  • · Replies 31 ·
  • · Replies 69 ·
  • · Replies 27 ·
  • · Replies 16 ·
