A question on Hilbert space theory
17 replies · 4K views
Let's say we have a self-adjoint, densly defined closed linear operator acting on a separable Hilbert space [itex]H[/itex]
[tex]A:D_{A}\rightarrow H[/tex]
Let [itex]\lambda[/itex] be an eigenvalue of A and let
[tex]\Delta_{A}\left(\lambda\right) = \{\left(A-\lambda \hat{1}_{H}\right)f, \ f\in D_{A}\}[/tex]
How do i prove that
[tex]D_{A}\perp \Delta_{A}(\lambda) \Leftrightarrow \bar{\Delta_{A}(\lambda)} \neq H[/tex].
Daniel.
matt grime said:
The domain of A is H.
No, Hurkyl is right. By the Hellinger-Toeplitz theorem, any self-adjoint operator whose domain is all of H is bounded. So, the best that one can expect for an unbounded self-adjoint operator A is that its domain D_A is a dense subset of H, as Daniel says.
As in they have poles? No, I think that is different, slightly, since we implicitly extend the codomain to have a point at infinity thus the functions are defined at all points of the domain. I get the impression here that there is no possible extension to an operator defined on the whole of H, though I may be mistaken in this assumption.
matt grime said:
Then why did the OP say we had an operator acting on H, if H is not the domain? Must just be a convention thing, but seems odd to me.
George Jones nailed it on the head. It's assumed unbounded, so by Hellinger-Toeplitz theorem
[tex]D_{A}\neq H[/tex]
but in order to be self-adjoint one must have that the closure of [itex]D_{A}[/itex] is H.
I guess the question still remains open. :rolleyes:
Daniel.
That can't be right.
Let A be any projection operator. So [itex]D_A = H[/itex]. Then, [itex]\Delta_A(0)[/itex] is the image of A. For most such operators, [itex]D_A[/itex] is clearly not orthogonal to [itex]\Delta_A(0)[/itex]... and yet [itex]\Delta_A(0)[/itex] is not dense in H.
Or, did you mean to only consider unbounded operators?
Yes, that operator is meant to be unbounded. Look at it this way, if it were bounded, why would one consider [itex]D_{A}[/itex] (the domain of A) dense in H but yet different from H ? It would have been simply H, as a bounded operator could be extended by continuity on all H...
Daniel.
But the case Hurkyl gave is a special case of what you wrote and it breaks down in the special case so why should it be true if we exclude the special case above? I think you should taken that post as a hint as to what you need to do. (Not that I know what the proof is, before you ask.) There are a lot of hypotheses on A up there, and H, so how are you attempting to use them?
Perhaps the problem that i stated is not quite correct. It would be fair to post the whole context. Here's a scanned version of page #89 of Ahiezer & Glazman's book. It's part of the 43-rd section which I'm trying to fully understand.
The thing i didn't understand is the argument he uses in the proof of theorem #2 namely that under the assumptions i stated in my first post (which appear on page 88).
He asserts that if [itex]Af=\lambda f[/itex] for an "f" both in the domain and in the range of A (closed, densly-defined self-adjoint linear operator) then
[tex]f\perp \Delta_{A}\left(\lambda\right) \Leftrightarrow \Delta_{A} \ \mbox{ is not everywhere dense in H}[/tex].
Huh? :confused:
Daniel.
Let me write [itex]D = D_A[/itex] and [itex]\Delta = \Delta_A(\lambda)[/itex] for simplicity.
Incidentally, it's easy to see that you can't have both [itex]D \perp \Delta[/itex] and [itex]\bar{\Delta} = H[/itex]: the inner product is continuous, and this implies that it's identically zero.
So let me see why you think it's trivial. If i assume
[tex]\bar{\Delta} =H[/tex]
, then
[tex]\bar{\Delta}\supset H \supset D[/itex]<br /> <br /> But [itex]D\perp \Delta[/itex] , so considering a sequence [itex]g_{n}[/itex] from [itex]\Delta[/itex] convergent to "g" in [itex]\bar{\Delta}[/itex], then from<br /> <br /> [tex]\langle f,g_{n}\rangle =0[/tex]<br /> <br /> it follows that<br /> <br /> [tex]\langle f,g\rangle =0[/tex]<br /> <br /> ,using continuity of the scalar product. <br /> <br /> So i proved that [itex]D \perp \bar{\Delta}[/itex]. Since above i assumed that [itex]D\subset \bar{\Delta}[/itex], it follows that [itex]D={0}_{H}[/itex] which is false. Ergo, the initial assumption is false.<br /> <br /> Daniel.[/tex]
Let my try and elaborate a bit on Hurky's last post.
Let [itex]U[/itex] be any any dense subset of [itex]H[/itex], and let [itex]v \in H[/itex] be such that [itex]\left< v , u \right> = 0[/itex] for every [itex]u \in U[/itex]. Then, by continuity and density (insert small analysis argument), [itex]v = 0[/itex].
Now, in the first half of the proof, one has [itex]\left< f , u \right> =0[/itex] for every [itex]u \in \Delta[/itex]. Therefore, if [itex]\Delta[/itex] were dense in [itex]H[/itex], then [itex]f[/itex] would have to be zero. But this can't be, since [itex]f[/itex] is an eigenvector.
Oops, I didn't see Daniel's last post.
I see, and there's no reverse of that statement. So I'm supposed to get that
[tex]\bar{\Delta}\neq H \nRightarrow D\perp \Delta[/tex]
, but instead one can find a nonzero vector from D which is orthogonal to [itex]\Delta[/itex].
Daniel.
