A second complex analysis question
The discussion revolves around solving the equation cos(z) = 2i, exploring various methods and approaches in complex analysis. Participants examine the implications of using different logarithmic functions and the multivalued nature of complex logarithms, while also considering the properties of exponential functions in the context of complex numbers.
  • Some participants outline the initial approach of rewriting cos(z) in terms of exponential functions, leading to a quadratic equation in w.
  • There is a discussion on the use of the principal logarithm versus the multivalued logarithm, with some arguing that the multivalued logarithm should be used to account for periodicity.
  • One participant expresses confusion about the relationship between Log(e^(iz)) and iz, noting that Log(e^(iz)) can yield multiple values depending on the integer k.
  • Another participant proposes a method that avoids logarithms entirely, suggesting a different approach to solving the problem.
  • Several participants derive specific solutions for z based on their approaches, including the use of arcsinh and the implications of periodicity in the solutions.
  • There is a suggestion that the general solution can be expressed in terms of k, where k is an integer, reflecting the periodic nature of the solutions.
  • Some participants question the correctness of signs and terms in their derived solutions, indicating uncertainty in their calculations.
Participants express differing views on the appropriate use of logarithmic functions, with some advocating for the multivalued logarithm while others prefer the principal logarithm. There is no consensus on the best method to solve the equation, and multiple competing approaches are presented.
Limitations include the dependence on the definitions of logarithmic functions and the unresolved nature of certain mathematical steps, particularly regarding the periodicity and signs in the derived solutions.
This discussion may be useful for students and practitioners of complex analysis, particularly those interested in the properties of complex functions and the nuances of logarithmic calculations in solving equations.
Tranquillity
So this time I have to solve cos(z)=2i
My approach:
cos(z)= [ e^(iz) + e^(-iz) ] / 2 = 2i
Rearranging and setting e^(iz) = w
we get a quadratic w^2 - 4iw + 1 = 0
The quadratic yields two solutions:
w=e^(iz) = i(2 + sqrt(5))
or e^(iz) = i(2-sqrt(5))And now my problem is here.
In the lectures we are only using the principal logarithm ie
"Let D0 be C with the origin and the negative real axis removed. Define, forz in D0,
w = Logz = ln|z| + iArgz.
Here Argz ∈ (−pi, pi) is the principal argument"Moreover, we have been given that
"It is not always true that Log (exp(z)) = z. e.g. z = 2πi gives
exp(z) = 1, Log (exp(z)) = Log 1 = 0."
So actually with what I was taught during lectures I cannot just take logarithms of both sides.
How should I solve the equation?Thank you for all the help!
Hi Tranquillity! :)
My approach:
I think you're mixing things up a bit.
Since $w=e^{iz}$, we'd get that:
$$iz_0 = \text{Log } w = \ln|w| + i \text{Arg } w$$
where $z_0$ is the solution corresponding to the principal value.
Well... you can take the logarithm of both sides, but you should take the multivalued logarithm instead of the principal one:
$$iz = \ln w = \ln|w| + i \arg w$$
where $\arg w = \text{Arg } w + 2k\pi i$ and $k$ an arbitrary integer.
Thank you very much for your reply :)
But does log(e^(iz)) always equal iz?
For example Log(e^(4i)) = 4i-2*i*pi
Basically by doing an exercise I have realized that
Log(e^(iz)) = iz - 2*k*pi*i, where k is an integer.
So does log(e^(iz)) always equal to iz but Log(e^(iz)) = iz - 2*k*pi*i?
I am confused!
Thanks for your reply again!
No.
What is true, is that $\log(e^{iz}) = iz + 2k\pi i$ for integers k.
This is multivalued.
Note the use of a lowercase $\log$ which is multivalued instead of the capitalized $\text{Log}$ that denotes the principal value.
Not precisely.
The Log gives $i$ times the principal argument (only 1 value).
$$\text{Log }(e^{iz}) = i \text{ Arg }(iz) = i \cdot (\Im(iz) \text{ mod }2\pi) = i \cdot (\Re(z) \text{ mod }2\pi)$$
Ok let's try to do it with the log instead of Log.
I have to solve e^(iz) = i(2+sqrt(5)) and e^(iz) = i(2-sqrt(5))
Take the first equation. Taking logarithms yields
i*z + 2*pi*i*k = ln(2+sqrt(5)) + i*((pi/2) + 2*pi*k), k is integer
pi/2 is the principal argument plus 2*pi*k to obtain arg z!
Solving yields z=(pi/2) - i* ln(2+sqrt(5))
But in the solution shouldn't there exist a term 2*pi*k due to periodicity?I have tried to solve the exercise before using Log instead of log and the second equation which was giving z = 2*k*pi - (pi/2)-ln(2-sqrt(5)) * i and when inputting in wolfram alpha, I was getting
-1.99999999999 i and with my previous solution for the first eqn I was getting 1.9999999999 i.
So two strange things: I don't get exact solution 2i and secondly my second solution was not giving
the correct sign.
Note that the principal argument of 2-sqrt(5) = -pi/2 and so my signs are correct!
Solving yields z=4*pi*k + (pi/2) - i* ln(2+sqrt(5))
But in the solution shouldn't be 2*pi*k only?I have tried to solve the exercise before using Log instead of log and the second equation which was giving z = 2*k*pi - (pi/2)-ln(2-sqrt(5)) * i and when inputting in wolfram alpha, I was getting
the correct sign.
[math]\displaystyle \begin{align*} e^{i\,z} &= i \left( 2 + \sqrt{5} \right) \\ e^{i \left( x + i\, y\right) } &= \left( 2 + \sqrt{5} \right) e^{i\left(\frac{\pi}{2}\right)} \\ e^{-y + i\,x} &= \left( 2 + \sqrt{5} \right) e^{i\left( \frac{\pi}{2} \right)} \\ e^{-y}\,e^{i\,x} &= \left( 2 + \sqrt{5} \right) e^{i\left( \frac{\pi}{2} \right)} \\ e^{-y} &= 2 + \sqrt{5} \textrm{ and } x = \frac{\pi}{2} \\ y &= -\ln{\left( 2 + \sqrt{5} \right)} \textrm{ and } x = \frac{\pi}{2} \end{align*}[/math]
So [math]\displaystyle \begin{align*} z = \frac{\pi}{2} - i\ln{\left( 2 + \sqrt{5} \right)} \end{align*}[/math].
That is a brilliant method avoiding any logarithms and any ambiguities!
Thank you very much!
The only thing I can add is that x could be (pi/2) + 2*k*pi where k is an integer for a complete solution, would you agree with that?
Let z= a+ib :
$$\cos(a+ib)=2i$$
$$\cos(a)\cosh(b)-i\sin(a)\sinh(b)=2i$$
Then solve the system of equations :
$$\cos(a)\cosh(b)=0$$
$$\sin(a)\sinh(b)=-2$$
Now, from the first equation we know that $\cosh(b)\neq 0 $ so we have have
$\cos(a)=0$ .
Let us use for example that $a=\dfrac{\pi}{2}$ and substitute in the second so we get $\sinh(b)=-2$ so $b=\text{arcsinh} (-2)$ but we know that :
$$\text{arcsinh(x)} =\ln \left( x+\sqrt{x^2+1}\right)$$
putting x = -2 we have :
$$\text{arcsinh}(-2) = \ln \left( -2+\sqrt{5}\right)$$
so one solution is: $$z=\frac{\pi}{2}+i\ln \left( -2+\sqrt{5}\right)$$
EDIT :
Clearly we can see that the other solution occurs when $a=\dfrac{3\pi}{2}$
So , the second solution is :
$$z=\frac{3\pi}{2}+i\ln \left( 2+\sqrt{5}\right)$$
Terrific! There are so many ways to solve this exercise, the thing is that we have learned only a particular material in order to use!
For example we did not do any other complex functions except sin, cos, exp and Log,
we are not even supposed to use the multivalued logarithm!
So I suppose the way we were supposed to solve it was by z=x+iy,
say that y = ln(...) and that e^(ix) = e^(i*pi/2) if and only if ix= i*pi/2 + 2*k*pi*i!
Thank you all guys for the replies and the valuable help!
Good to know there are still people trying to help with other people problems!
Have a good day all! :)
So we can conclude that the general solution is :
$$z=\frac{(2k+1)\pi}{2}+i\ln \left( (-1)^k2+\sqrt{5}\right)$$
Shouldn't be z= (pi/2) + 2*pi*k - ln (2+/- sqrt(5))*i, where k in Z ?
Since following Prove it's way, we have for e^(iz) = i(2+sqrt(5))
that y=-ln(2+sqrt(5)) and that e^(ix) = e^(i*pi/2) which holds if and only if ix=i*pi/2 + 2*pi*k
Similarly for e^(iz) = i(2-sqrt(5))
that y=-ln(2-sqrt(5)) and that e^(ix) = e^(i*pi/2) which holds if and only if ix=i*pi/2 + 2*pi*k
and so the general solution becomes
z=x+yi = (pi/2) + 2*pi*k - ln (2+/- sqrt(5))*i, where k in Z
The most general solution for [math]\displaystyle \begin{align*} e^{i\,z} = i\left( 2 + \sqrt{5} \right) \end{align*}[/math] is [math]\displaystyle \begin{align*} z = \frac{\pi}{2} + 2\pi \,k - i\ln{\left( 2 + \sqrt{5} \right) } \end{align*}[/math].
To solve [math]\displaystyle \begin{align*} e^{i\,z} = i\left( 2 - \sqrt{5} \right) \end{align*}[/math] will take a little bit more work, because [math]\displaystyle \begin{align*} 2 - \sqrt{5} < 0 \end{align*}[/math]. This means that [math]\displaystyle \begin{align*} i \left( 2 - \sqrt{5} \right) \end{align*}[/math] points DOWNWARDS from the origin, making an angle of [math]\displaystyle \begin{align*} -\frac{\pi}{2} \end{align*}[/math] (or any integer multiple of [math]\displaystyle \begin{align*} 2\pi \end{align*}[/math] added or subtracted to it), and its magnitude is [math]\displaystyle \begin{align*} \sqrt{5} - 2 \end{align*}[/math].
So that means
[math]\displaystyle \begin{align*} e^{i\,z} &= i\left( 2 - \sqrt{5} \right) \\ e^{i\left( x + i\,y \right)} &= \left( \sqrt{5} - 2 \right) e^{i\left( -\frac{\pi}{2} + 2\pi\,k \right)} \textrm{ where } k \in \mathbf{Z} \\ e^{-y + i\,x } &= \left( \sqrt{5} - 2 \right) e^{i \left( -\frac{\pi}{2} +2\pi \, k \right)} \\ e^{-y}\, e^{i\,x} &= \left( \sqrt{5} - 2 \right) e^{i\left( -\frac{\pi}{2} + 2\pi\,k \right)} \\ e^{-y} &= \sqrt{5} - 2 \textrm{ and } x = -\frac{\pi}{2} + 2\pi\,k \\ y &= -\ln{\left( \sqrt{5} - 2 \right) } \textrm{ and } x = -\frac{\pi}{2} + 2\pi\,k \end{align*}[/math]
You can not put the two solutions together as you have done.
Thanks for that! :)
24K
